Power Steering Pump Pulley Removal - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 26th, 05, 12:16 PM Thread Starter
Where do you find the tool for removing a stamped pulley? I've mangled mine trying to use a normal puller...contrary to the recommendations in the shop manual. Pump is original from 66 so I was planning to replace anyway.
icedog75 is offline
post #2 of 9 (permalink) Old Dec 26th, 05, 12:33 PM
Smile Re: Power Steering Pump Pulley Removal
If the pulley is bad, I have removed them in a press.
TJS69 is offline
post #3 of 9 (permalink) Old Dec 26th, 05, 02:48 PM Thread Starter
It was actually OK till I got to it. I needed to remove the pulley to remove the cradle for the new pump. I guess I'll to what I have to to get it off.
icedog75 is offline
post #4 of 9 (permalink) Old Dec 26th, 05, 03:08 PM
ZZ_430's Avatar
I bought the set from OTC many years ago, best money I ever spent.
Similar to this set:
http://www.jcwhitney.com/autoparts/P...14/TID-8014524
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 9 (permalink) Old Dec 26th, 05, 08:47 PM
i rented that set from autozone for free...
67LS1RSCamaro is offline
post #6 of 9 (permalink) Old Dec 27th, 05, 08:43 AM
Bob
I got mine from Harbor Freight for about $10 a few years back. Have used it a few times, but well worth the $$
Bob
69vert is offline
post #7 of 9 (permalink) Old Dec 27th, 05, 09:26 AM Thread Starter
Tks all. I just returned from Autozone. Ordered the replacement pump and will use their tool when it arrives.
icedog75 is offline
post #8 of 9 (permalink) Old Dec 27th, 05, 04:57 PM
remember to use the tool to put it back on...DON'T USE A HAMMER!!
just in case you didn't know that already...
mike
emtcee1973 is offline
post #9 of 9 (permalink) Old Dec 27th, 05, 05:32 PM Thread Starter
Noted...shop manual suggests using the nut to draw the new pulley on...won't be using a hammer.
icedog75 is offline
