Carb and intake question - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 28th, 05, 02:09 AM Thread Starter
I recently purchased a edelbrock performer series 800 cfm carb for my 1967 Camaro 350. I have read many posts that have said not to even bother with a carb that high, that the 600 series is better. Is this correct, and if so what intake should i get if i get the 600? Thanks
LHSCub6 is offline
post #2 of 8 (permalink) Old Dec 28th, 05, 05:50 AM
67 Convertible's Avatar
Re: Carb and intake question
I have a 327/275 in my '67. I went with the EDL-21011 intake with an EDL-1406, 600 cfm w/elect. choke and a Lunati 00016 cam. Car runs great, no problems with the carb at all, very happy with this set up. Not a 350, but hope this helps.
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
67 Convertible is offline
post #3 of 8 (permalink) Old Dec 28th, 05, 06:37 AM
the intake should be correct for your engine...if you are only revvin to 5000 then stickwith the performer or something equivalent.if your makin good power in the 6000 rpm range then switch to performer rpm style...anything higher use an open plenum manifold......the 800 edelbrock is quite large for a mild 350 even more so if its an automatic with no stall....a smaller carb will always be more responsive to a limit when you need more cfm for power.......www.hardcoreparts.ca
pro1 is offline
post #4 of 8 (permalink) Old Dec 28th, 05, 07:28 AM
I second pro1. He is correct a smaller carb would be more suitable for your engine. Your intake however is a good choice. IMHO
TexasPerfProd is offline
post #5 of 8 (permalink) Old Dec 28th, 05, 10:30 AM
Wes
I'm forever the Q-Jet fan on milder builds,..750 cfm, easy to tune, etc.
Of course you'll need an intake that accomodates a spread-bore carb, but nothing like the ol' Q-jet when you kick in those big secondaries!
My opinion,..good luck regardless!
Straight-line-69 is offline
post #6 of 8 (permalink) Old Dec 28th, 05, 06:39 PM Thread Starter
has anyone heard about, or had any problems with the edelbrock 800 cfm. I have heard many problems with the 750 series, but i think the 800 fixed those problems. I might give it a try with a rpm air-gap intake.
LHSCub6 is offline
post #7 of 8 (permalink) Old Dec 28th, 05, 10:27 PM
You don't want an RPM Air Gap, go with a Performer intake and the 600cfm carb as the others have mentioned. Your 327 will idle better and be more responsive.
and
Brian Lewis is offline
post #8 of 8 (permalink) Old Dec 29th, 05, 10:00 AM
The 600cfm rating is appropriate for a street driven SBC350 if the carb is a square bore carb (as most of the Holley carbs are). If you use a spread bore (like the Q-jet or Edelbrock) then you can affort to go a bit higher. As for intakes, on a street motor, just about any dual plane intake will work. I run the Edelbrock Performer RPM.
For square bore carb sizing, this formula will get you in the ball-park at 100% volumetric efficiency. In reality, the VE will depend on the heads, cam and other variables. 80% is realistic for a stock engine, 90% or higher can be obtained with the right heads and cam (though the power band is likely to be much more narrow). In any event, multiply the result from the formula by the VE (i.e. multiply by .80 if the VE is 80%).
CFM = MAX_PRM * DISPLACEMENT / 3456.
dnult is offline
