Cowl Induction Air Cleaner Spacing - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 28th, 05, 11:40 AM Thread Starter
Michael
I want to order the correct cowl induction aircleaner so my cowl hood is functional. My 350 has a quadrajet carb and a performer intake - not sure if I need to order the spacer ring for the 350 or for the 302 since the performer is higher than stock but probably not as high as the original intake on the 302. Anyone had any experience with this?
Garnet Van Nuys '69, 350/4 spd, deluxe int, endura, owned since 1979 - my first car
69isfine is offline
post #2 of 5 (permalink) Old Dec 31st, 05, 10:40 AM Thread Starter
Michael
Re: Cowl Induction Air Cleaner Spacing
Anyone?
69isfine is offline
post #3 of 5 (permalink) Old Dec 31st, 05, 10:59 AM
I had an old Edelbrock Performer SP2P with a Holly 1850 on it, and I used the 302 setup which was just about right. Theres no way the 350 one will fit on anything over stock height. Your only choice is going to be to use the 302 or none, unless you want to cut one down.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 5 (permalink) Old Dec 31st, 05, 12:00 PM
Did we cover this before,,, I am using the cowl air cleaner with out the 1 3/4 spacer ring... on the stock Z manifold and Holley. For some reason there is not enuff room to use this spacer ring between the ac base and sealing hat.
TC # 349
zdld17 is offline
post #5 of 5 (permalink) Old Jan 2nd, 06, 09:44 AM Thread Starter
Michael
Is there any difference in height between the Quadrajet and the Holley?
69isfine is offline
