oily plugs - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 28th, 05, 10:32 PM Thread Starter
oily plugs
HI All, went to do a plug change tonight. All 8 plugs have heavy carbon buildup. Also all 8 plugs have either Gas or oil on all the threads (I can't tell which it is). It smells like gas but when I rub it off with my fingers it is very sticky like tar....How do I tell if it is gas or oil?
If it is oil why would all 8 plugs be covered with it? The motor is a zz4 with less than 2K miles.
Chris
freebird is offline
post #2 of 2 (permalink) Old Dec 28th, 05, 10:36 PM
Wes
Re: oily plugs
You're probably rich at idle and/or cruise,..and you may need a step hotter plug.
Also, check you float level.
Good luck!
Straight-line-69 is offline
