Lots of cranking to get started? - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 29th, 05, 04:34 PM Thread Starter
I am looking for some advice on a starting problem. When hot, I have to crank the starter for 10 seconds or so to get it started. When It does start, it is very rough for about 5 seconds and then smooths out nicely. Car runs great and no other problems other than this starting problem. Could this be a vaccum advance issue? Any ideas are welcomed.
Everything is new
Thanks alot.
Sgrouse is offline
post #2 of 9 (permalink) Old Dec 29th, 05, 04:40 PM
ZZ_430's Avatar
Re: Lots of cranking to get started?
Put a 1/2" phenolic spacer under that Holley carb, or a 1" would even be better if you have hood clearance.
The gas in the carb percolates when hot soaking.
Also check the float levels.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 9 (permalink) Old Dec 29th, 05, 06:15 PM Thread Starter
I do have one of those spacers.
Sgrouse is offline
post #4 of 9 (permalink) Old Dec 29th, 05, 06:27 PM
Royce
Is your spacer aluminum or does it look like wood? If it is aluminum it won't help at all with heat soak. From the description, I agree that could very well be the problem.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #5 of 9 (permalink) Old Jan 1st, 06, 06:49 PM Thread Starter
The spacer is not aluminium. It is that wood looking plastic stuff. I bought the spacer before the problem started.
Sgrouse is offline
post #6 of 9 (permalink) Old Jan 1st, 06, 11:16 PM
Too much choke perhaps? If you are running an electric choke, those things tend to cool down when you shut the engine off - even after the engine is warmed up good. If it is choking too much it will give you the problem you described.
If you tap the accelerator pedal before starting it will set the choke. If you don't tap it, the choke will stay open. Any chance you are tapping the pedal on your hot engine, when no tap would work better? Carberated engines have a personality all their own and it seems each are a bit different. If you don't caress them the right way, they'll give you trouble.
dnult is offline
post #7 of 9 (permalink) Old Feb 5th, 06, 08:02 AM Thread Starter
I have a 1/2 inch phenolic spacer. Could it be that 1/2 inch is not enough and I should try a 1 inch spacer to dissipate heat?
Sgrouse is offline
post #8 of 9 (permalink) Old Feb 5th, 06, 08:18 AM
I agree with Dave. I always do a hot restart without touching the gas pedal, fires right up. Then if I start driving right away, it wants to fast idle a bit until the electric choke warms up.
post #9 of 9 (permalink) Old Feb 5th, 06, 08:33 AM
1/2 is enuff , 3/4 is better depending on your hood clearance. All you want to do here is lessen the heat soak from the manifold.
As mentioned also , check the choke setting ,, it should only come on at low temps and when it does,, make sure the choke flap is not closed all the way,, leave about 1/4" open..
Need to also check your power valves,, they could be leaking into to manifold at shut down , then flooding the manifold floor with fuel.
TC # 349
zdld17 is offline
