can someone tell me???? - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 1st, 07, 02:58 PM Thread Starter
i'm building a roll cage for my 1984 z/28 and was wondering if i do this will i still need sub frame connectors if the cage is welded to the front and rear sub frames?
chadrafuse is offline
post #2 of 2 (permalink) Old Feb 1st, 07, 03:15 PM
Re: can someone tell me????
You can weld to the frame or use 6" x 6" plate welded in. Look up Dragfabricator (Brain) or do a search on "rollbar".
I would recommend sub connectors regardless.
68 Camaro~LSx ~all motor
