2012 Camaro - Service Stabilitrac message - Team Camaro Tech
Sixth Generation Forum to discuss the upcoming 6th Generation Chevrolet Camaro
post #1 of 6 (permalink) Old May 22nd, 19, 06:39 PM Thread Starter
Keith
I was driving my 2012 SS last weekend and while accelerating, the engine light came on, as did all the ABS and traction control lights. A Service Stabilitrac message also appeared in the VID.
I checked for codes and only had a P0300 - general engine misfire fault.
The car was running noticeably rougher. I checked the fuel pressure, vacuum and both were fine.
I did find zero compression in cylinder #3. I took it to the dealer and they indicated that I had a bad valve spring.
They replaced it, and it runs fine now.
Sosh67 is offline
post #2 of 6 (permalink) Old May 24th, 19, 02:04 AM
Kevin
Re: 2012 Camaro - Service Stabilitrac message
Wrong section. This is the 1st generation (67 to 69) Camaro section.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #3 of 6 (permalink) Old May 24th, 19, 06:10 AM
Apparently, this thread has been moved already. Magic happens ...
post #4 of 6 (permalink) Old May 24th, 19, 07:58 AM
Kevin
KevinW's Avatar
Is a 2012 a 6th generation? I was not sure.
Kevin
KevinW is offline
post #5 of 6 (permalink) Old May 24th, 19, 08:25 AM
Yes, starts at 2012.
post #6 of 6 (permalink) Old May 24th, 19, 05:19 PM
Garth
Umm no! 2015 was the end of the 5th gen.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
1967 R/T
1977 Power Wagon
69L48Z27 is offline
Chevrolet Camaro ZL1 2012 bwcamaro68 Fifth Generation 19 Aug 22nd, 11 03:54 PM
Mustang Boss 302 2012 ??? Camaro Z/28 2012 bwcamaro68 Bench Racing 7 Aug 17th, 10 08:56 PM
Barrett Jackson Monday photos... xplantdad Bench Racing 15 Jan 15th, 08 05:46 PM
MAILBAG: Readers give reactions on Camaro OverAnxious Fifth Generation 0 May 18th, 06 07:07 AM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
