Elec. ignition choices ? - Team Camaro Tech
post #1 of 21 (permalink) Old Feb 5th, 07, 09:56 AM Thread Starter
click's Avatar
Im going to be getting rid of my Mallory Unilite system and going to either a Petronix or Breakerless system.
Breakerless is one wire but Petronix is 2 wire. Ive read other posts of guys that have the Petronix and like it but anyone used the Breakerless?
Any thoughts on which would be better for my pretty much standard 350/255 ?
click is offline
post #2 of 21 (permalink) Old Feb 5th, 07, 10:13 AM
DjD
DjD's Avatar
Re: Elec. ignition choices ?
Jim - I would look into the new MSD electronic dist. You set the advance curve with small switches inside the dist. Totally adjustable, it's called the Digital e-curve and is a stand alone not requiring an MSD box. Might be a bit expensive but caught my eye as a desirable item...
...Dennis
DjD is offline
post #3 of 21 (permalink) Old Feb 5th, 07, 10:20 AM Thread Starter
click's Avatar
I looked at them Dennis MSD Dist but none were standard plug wire cap type. I need to keep the profile standard and low to clear the cowl induction air filter stuff. All the dist. in the MSD site were the taller HEI type, except a 6 cylinder version I will keep browsing them anyway. Thanks.
click is offline
post #4 of 21 (permalink) Old Feb 5th, 07, 10:50 AM
DjD
DjD's Avatar
I didn't realize the cap was that tall on it, it is a small body and I assumed it took hei wire ends and was stock size...
Might look into a stock points dist (real cheap) and sending it to Dave Ray www.davessmallbodyheis.com and he'll rebuild it to be an hei with a stock cap. He straightens the shaft, re-chromes it and basically blueprints it as he rebuilds it. I've had one in the White Wonder for years and am very happy with the performance of it.
...Dennis
DjD is offline
post #5 of 21 (permalink) Old Feb 5th, 07, 11:14 AM Thread Starter
click's Avatar
My current dist. could be rebuilt plus I have a box of 5 other dist. that could be rebuilt as well. Id like to keep the old style plug wires for their look but I will call Dave and ask him about options, thanks emailed him for his ideas now
click is offline
post #6 of 21 (permalink) Old Feb 5th, 07, 11:26 AM
Farm Boy's Avatar
The Petronix 1181 is a well designed unit that replaces the points and condenser. It not only maintains a stock look but also works well with a stock coil and resistor wire. The black wire connects to the negative (-) side of the coil just like the wire that went to the points, and the red wire is connected to a 12v source to power the module. The “ING” connector on the fuse block is a good place to connect the red wire.
I used the stock coil when I installed the 1181 Ignitor in my car as I did not want to eliminate the resistor wire. It works great all the way up to 6500 RPM.
Farm Boy is online now
post #7 of 21 (permalink) Old Feb 5th, 07, 11:32 AM Thread Starter
click's Avatar
thanks steve my engine will never see 6500rpm, I hope
click is offline
post #8 of 21 (permalink) Old Feb 5th, 07, 02:32 PM
I've used the Pertronix module with good success and Crane also has one (called XRi I think) which has a built in adjustable rev limiter. I have one in my current Camaro and it has been no problem. It is roughly the same price as the Pertronix. Both are nice if you want to retain the stock distributor.
67funcar is offline
post #9 of 21 (permalink) Old Feb 5th, 07, 03:31 PM Thread Starter
click's Avatar
Ok If I send in a dist. to be rebuilt, how does a fella know which one to send in? Do the weights and springs have to change, what about vac can? Different one for that too?
I have 5 spare dist. and the Unilite one thats in the car now. Would any of these be better than another?
1111152 from 1966 327-275 w/o AIR
1112844 from 1974 350/145 Camaro
1111249 from 1967 327/275 Camaro
1111150 from 1966 283/195 ??
1111483 from 1968 327/210 Camaro
click is offline
post #10 of 21 (permalink) Old Feb 5th, 07, 03:53 PM
DjD
DjD's Avatar
Jim - I would talk to Dave, he would know. I'm guessing though but it probably doesn't matter as he recurves the dist to your combo. An alum over a steel might be the decider... He will request information such as compression, carb used, headers, cam spec's, plugs etc. He will set you up with what you you want as far as vacuum advance (modified stock style or an adjustable) and will provide extra springs so you can fine tune. You also have a choice of cap hei style or point style and he provides all part numbers and complete instructions to get the most out of the new ignition. Best part is if something does fail you can get parts at any parts house without waiting over night for something from the wherehouse... Not that breakdown is a problem, mines been in since before the Seattle trip and the engine fires just like the day I installed it...
...Dennis
DjD is offline
post #11 of 21 (permalink) Old Feb 5th, 07, 04:05 PM
I would guess theresa bunch of people here who'd know what aftermarket distributor besdies a unilite will fit under a cowl air cleaner?
MSD does sell a cap with normal plug wires, but of course you'd have to buy it in addition to the hei terminal cap it comes with, and I don't know how tall it is.
I'm sure Dave builds a great dizzy, but somehow I never liked the idea of hanging the module outsaide the case. It wouldn't last a month with me as often as I take a hose to her.
post #12 of 21 (permalink) Old Feb 6th, 07, 02:27 PM
Originally Posted by JimM View Post
...somehow I never liked the idea of hanging the module outsaide the case. It wouldn't last a month with me as often as I take a hose to her.
If the terminals are greased up good with dielectric goo, there shouldn't be a problem. But it definately would be a tune-up item to inspect periodically. So far, mine has nothing but dust on it. Hopefully I'll get it painted one day and run it through some puddles.
dnult is offline
post #13 of 21 (permalink) Old Nov 18th, 08, 10:22 AM
Randy
I went with the MSD E-Curve and really like it. Click on my username and go to my posts, I have one large post with info you might be interested in on the digital age and the E-Curve. Randy
camminc is offline
post #14 of 21 (permalink) Old Nov 18th, 08, 07:11 PM
I have 31 Dave's small-body HEI conversions, from his MSD trigger only, regular HEI for carburetted engines, and his new ones, EFI-HEI feedback for EFI systems. ALL use the module OUTSIDE the body, NONE have ever had weather issues. One of the systems is on one of my I/H Travel-All's, and it runs in the mud and snow all the time in winter, never had an issue with his stuff. He is now doing one for my 32nd project, 1965 Pontiac GTO, 455, 4 speed, with tri-power.
I used to use a lot of other systems on my project vehicles, with mediocre to bad results. Now, when I get a new project to do, as I now have waiting in the driveway, project number 33, I don't even go for the other systems, except for an MSD box if that project gets one (and, then, Dave gets the distributor for it for one of his MSD trigger only conversions). I just remove the distributor, and, send it to Dave, along with one of his specification sheets. It comes back right, the first time, with no hassles, no problems.
His web site is - davessmallbodyheis.com - His e/mail is - [email protected]
Regards,
Milton
The Devil's advocate is offline
post #15 of 21 (permalink) Old Nov 18th, 08, 08:32 PM
David Pozzi
davidpozzi's Avatar
You could mount the module anywhere, even under the dash, just mount it on a good heat sink.
davidpozzi is offline
Car Running....Then lost all power to Ignition! HELP jsabowabo Electrical & Wiring 10 Jul 20th, 06 06:40 PM
Ignition problems tstrobl1 Electrical & Wiring 5 Feb 3rd, 06 04:44 AM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 12:50 PM
2001 Z28 ignition switch/security system malfunction 45Auto Electrical & Wiring 3 Sep 22nd, 05 08:19 AM
Column ignition help soda Electrical & Wiring 3 Apr 9th, 02 05:07 AM
