ignition switch malfunctioning - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 19th, 07, 06:48 AM Thread Starter
car starts and when key is released car dies.....any suggestions? dd
ddtootall is offline
post #2 of 5 (permalink) Old Feb 19th, 07, 07:04 AM
DjD
DjD's Avatar
Re: ignition switch malfunctioning
You're missing a hot lead or it's gone open. When you turn the key it starts because there is a secondary batt path used only when the key is turned all the way.
...Dennis
DjD is offline
post #3 of 5 (permalink) Old Feb 19th, 07, 06:36 PM
Larry
Look at my drawing below. Use the wiring diagram on the right side of the page. From the ignition switch, follow the 12 PNK wire to the firewall bulkhead connector through the resistance wire to the coil. That's where your break most likely is.
As a test, turn the ignition key to "ON", engine not running, and see if there is voltage at the positive terminal of the coil. Let us know what you get.
Larry
69-er is offline
post #4 of 5 (permalink) Old Feb 19th, 07, 06:59 PM
Harley
wiskeesour's Avatar
How many keys are on your keychain? I ended up buying a 68 RS 375hp car for $5500 for the same problem. the weight of all the keys(truckdriver) he had on the keychain for his car would move the switch just right and kill it.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #5 of 5 (permalink) Old Feb 19th, 07, 08:43 PM
Larry
I forgot about that possibility. Of course, that wouldn't be the case for a 69 or later. Don't what dd has.
Larry
69-er is offline
99 Wiring Diagram Power Door Lock DONZIGW Electrical & Wiring 1 Aug 16th, 05 10:59 PM
Ignition Switch? Neutral Safety Switch? planejane Electrical & Wiring 10 Jun 17th, 05 04:04 AM
Ignition switch - help on identifying kfinsrud Troubleshooting 5 May 12th, 05 10:49 AM
Starting Issue -- Starts When Ignition Switch is Released from Start to On SteveN Troubleshooting 4 Oct 2nd, 03 04:46 PM
