side marker lights always on - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 20th, 07, 10:59 PM Thread Starter
john
wagonman's Avatar
ok i know some of you guys have seen this before..
my front side markers lights stay on.
when i connect my batt up, the horns chirp and the markers lights go on. key off and all switches off!
now when i disconnect my horn wire from the horn relay.(the wire from the horn button) baaammmm! side markers go out....
so the marker lights are getting there power from the horn relay throught the horn groung wire..
why?
wagonman is offline
post #2 of 4 (permalink) Old Feb 21st, 07, 03:38 AM
Re: side marker lights always on
Aftermarket alarm system? If so, it may need resetting.
Otherwise, if 1st Gen car, horns are the green wire from relay. Horn button is black wire. Side markers are the brown wire (supply) and black wire (return). So the two black wires may be crossed.
post #3 of 4 (permalink) Old Feb 21st, 07, 09:26 PM Thread Starter
john
wagonman's Avatar
well i looked and the two black wires cannot be crossed. the return for the lights has a connector that grounds to the rad support. the other black wire(horn) has a connector that connects to the horn relay. two totally different connectors.
i still feel that the lights are getting there power from the horn relay. well they have to since the only wire connected to the batt goes to the horn relay......motor insnt in the car....no batt cables.
wagonman is offline
post #4 of 4 (permalink) Old Feb 23rd, 07, 10:35 PM Thread Starter
john
wagonman's Avatar
anybody?
wagonman is offline
68 side marker lights mxquattro Body Shop 5 Sep 21st, 06 05:30 AM
Driver's side too low? 15x7 ralley w/235/60/15 rubs fender lip, frame, inner fender.. Brentmc Brakes, Suspension & Steering 15 Oct 21st, 05 02:09 PM
Distributor problems? JimM Engine 27 Jun 23rd, 05 07:19 PM
Rear side marker lights placement rusty Z Body Shop 0 Sep 22nd, 04 06:02 AM
69 RS side marker light bulb removal j79l82 Tech 2000 2 Feb 5th, 00 05:28 PM
