Key buzzer not working - Team Camaro Tech
post #1 of 8 (permalink) Old Feb 22nd, 07, 04:15 AM Thread Starter
ENP
I hooked up all the new wiring in my 69 camaro but the key buzzer isn't working. The horn works but no buzzer. The horn relay is new. Any idea what can cause this. Should I even worry about it.
ENP is offline
post #2 of 8 (permalink) Old Feb 22nd, 07, 04:21 AM
Re: Key buzzer not working
If it were me, I wouldn't worry about it, I disconnected mine.
However, no voltage at the pink/blue wire from the key switch. Voltage comes from the door jam switch, blue wire. Or, a bad ground at the relay.
post #3 of 8 (permalink) Old Feb 22nd, 07, 09:23 AM Thread Starter
ENP
If there is a bad ground at the relay would the horn still work. Door jam switches are new. Console and dome light work when the door is open.
ENP is offline
post #4 of 8 (permalink) Old Feb 22nd, 07, 10:13 AM
Still could be a bad ground or a faulty connection at the firewall connection.
But at any rate power from door switch to key slot on the column to f/w to relay to radiator support.
post #5 of 8 (permalink) Old Feb 22nd, 07, 05:43 PM
Larry
One of my diagrams I've attached might help.
Larry
69-er is offline
post #6 of 8 (permalink) Old Feb 22nd, 07, 07:48 PM
Here is a link to four pages of key buzzer diagnosis. It is in the Corvette section but the key buzzer switch and vehicle wiring was all the same.
http://jimshea.corvettefaq.com/wp-co...rDiagnosis.doc
JIML82
JIML82 is offline
post #7 of 8 (permalink) Old Feb 23rd, 07, 05:01 AM
I was thankful when mine stopped working!
Dan
'68 Camaro Convertible
dschribs is offline
post #8 of 8 (permalink) Old Feb 23rd, 07, 03:36 PM Thread Starter
ENP
Thanks for all the input, I might not want it to work after all.
ENP is offline
key buzzer cajunbaby100 Electrical & Wiring 9 Jun 10th, 14 07:24 PM
key remind buzzer utility5 Electrical & Wiring 19 Jan 31st, 07 11:27 AM
key buzzer Gary Dorion Electrical & Wiring 3 Aug 2nd, 06 09:08 AM
help installing original key buzzer... meyerlansky Electrical & Wiring 2 Jul 6th, 06 06:12 PM
What is this buzzer that won't turn off? Subtlesustain Electrical & Wiring 1 Sep 2nd, 05 03:30 AM
