1989 rs 305 has "SECURITY" dummy light on! - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 26th, 07, 12:58 AM Thread Starter
Exclamation 1989 rs 305 has "SECURITY" dummy light on!
what in the heck does this mean? my security dummy lighton my dash keeps popping on! what does this mean? what security features does my 89 rs even have? please help!
scooterist50 is offline
post #2 of 8 (permalink) Old Mar 26th, 07, 03:43 AM
Kevin
SixtyAte's Avatar
Re: 1989 rs 305 has "SECURITY" dummy light on!
You have a VATS ( Vehicle Anti-theft System) in that car. Most times the contacts in the ignition a dirty or the chip on the key is bad. Go to a locksmith and have them check the frequency of the chip and cut you a new key. I also sugest that you clean the contacts using contact cleaner on a q-tip.
Kev
SixtyAte is offline
post #3 of 8 (permalink) Old Mar 26th, 07, 11:35 PM Thread Starter
tried cleaning but no good. it helped though the light does still randomly flash. will any locksmith do it? or just gm. is it expensive to get the frequency checked, and is the key itself expensive? im looking for a price range here
thanks sixtyate
youve been really helpful -alex
post #4 of 8 (permalink) Old Mar 27th, 07, 03:45 AM
Kevin
SixtyAte's Avatar
Alex...
The locksmith just places the key in a reader and it tells them the code number. Then they get a blank key with that code and cut to match your. I would say about $10.00 ballpark total at most locksmiths. You do not have to go to a gm dealer however I don't think WAllymart will have the proper tools to decode the key and have the proper key blank.
Kev
SixtyAte is offline
post #5 of 8 (permalink) Old Mar 27th, 07, 05:28 AM
Its probably the key tumbler/socket in the steering column is making intermitent contact with the key resistor.
Replacement tumbler requires steering wheel removal. Dealership requires ownership proof of the car.
post #6 of 8 (permalink) Old Mar 27th, 07, 11:15 PM Thread Starter
then how do i bypass it?
post #7 of 8 (permalink) Old Mar 31st, 07, 01:29 PM
http://www.12vp.com/info_resistors.htm
Greg U
undee72Z is offline
post #8 of 8 (permalink) Old Mar 31st, 07, 09:25 PM
use a multimeter to find out the resistance in the key chip...go to radio shack and buy a resistor of said value...look on the steering column for two thin white wires...they come from the ign tumbler...cut them and install each end of the resistor to a wire, and tape them off...but everett has the correct fix..probably easier too...
kustomwerker is offline
Outer Left Tail Light Won't Light Up SFCamaro Electrical & Wiring 2 Oct 6th, 06 01:05 PM
parking brake dummy light scottl2 Electrical & Wiring 5 Jul 25th, 06 01:55 PM
67 camaro temperature sensor for dummy light DALEJRFAN8 Electrical & Wiring 5 Dec 31st, 05 11:37 AM
ammeter reading zero but dummy light working slickrick68 Electrical & Wiring 18 Sep 11th, 04 08:42 AM
Temp Dummy Light - What Sensor? Brian Lewis Heating & Cooling 1 Oct 17th, 03 06:48 AM
