69 underdash harness help - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 27th, 07, 04:52 PM Thread Starter
I have a post regarding my Neutral switch and reverse lighs, and I have that fixed. Now, I have a plug under the dash, near the column connector, that has only two wires, one yellow and the other black. I have a picture of this loose plug, if you think you know it, but want to see to be sure, I will email it to you.. email me at info at onqracing dot com doing the normal decifer of the email address. Now, this used to be a shift on the column car, but I made it into a consol cruser. Non AC..
TIA
hugger69327 is offline
post #2 of 5 (permalink) Old Mar 27th, 07, 05:57 PM
Kevin
KevinW's Avatar
Re: 69 underdash harness help
Hazzard light blinker?
Kevin
KevinW is offline
post #3 of 5 (permalink) Old Mar 27th, 07, 06:13 PM
mark
mark x22's Avatar
its the radio .
mark x22 is offline
post #4 of 5 (permalink) Old Mar 27th, 07, 06:13 PM Thread Starter
The hazards still work.. Does the hazard light plug into the same larg connector on the column?
post #5 of 5 (permalink) Old Mar 27th, 07, 06:15 PM Thread Starter
Radio... Ahh.. There is just a whole in the dash where that was.. Makes sense.. thanks.. to be sure, I will check it with a meter, and then again with the radio fuese pulled..
69 console harness questions jimi302z28s Electrical & Wiring 5 Jul 1st, 06 05:35 AM
Carb Dates DZ Fool Tag Team 16 Apr 2nd, 06 12:44 PM
69 Turn Signal Switch Harness Adapter 69-er Electrical & Wiring 1 Aug 9th, 05 07:19 PM
67-68 underdash harness tim Electrical & Wiring 5 Apr 14th, 05 01:25 PM
few wiring questions (painless and autometers) tail light harness MY FIRST 69 Electrical & Wiring 5 Nov 3rd, 04 07:36 PM
