1968 RS Tach question - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 5th, 07, 04:08 PM Thread Starter
I recently added a original factory tach and console gauge cluster. I replaced the underdash harness with a factory harness for gauges , also changed the engine harness to a facory model for gauges. The console gauges work fine but I am trying to fiqure out how to hook the tach up. Are all the wires alraedy running to the tach or do I have to run a seperate wire. I am using a factory GM electronic dist. So what I cant fiqure out is are all the wires alraedy there since I have harnesses designed for gauges or do I still need to wire the back of the tach. Thanks in advance for any help. Richard
richar22 is offline
post #2 of 5 (permalink) Old Apr 5th, 07, 06:53 PM
john
wagonman's Avatar
Unhappy Re: 1968 RS Tach question
if you got an engine harness for a console with gauges then there should be a brown wire near your coil. connect it to your coil on the neg side..
i didnt see anywhere that you got the plastic instrument circuit board for a tach gauge cluster.
did you?
hmmm................
check out ricks part #CDP-15 $69.96
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #3 of 5 (permalink) Old Apr 6th, 07, 09:40 AM Thread Starter
yes, I changed the whole cluster , It is original with the correct circuit board for tach, so does this mean it should just be the brown wire to neg on coil or in mycase tach on electronic ign. Thanks
richar22 is offline
post #4 of 5 (permalink) Old Apr 6th, 07, 05:45 PM
yes you need a wire to tach on the electronic ignition
jaguareats is offline
post #5 of 5 (permalink) Old Apr 6th, 07, 05:51 PM
I believe on 68's, the tach wire was separate from the other harnesses, just a wire with a terminal on both ends that runs from the tach signal terminal on the cluster thru the firewall to the coil.
1968 twin turbo question crackyflipside Performance 4 Aug 1st, 05 07:24 PM
1968 Camaro Question Riccbhard Electrical & Wiring 3 Jul 16th, 05 11:23 PM
another tach question kennys Electrical & Wiring 15 Mar 23rd, 05 04:05 AM
140 AMP Alternator in 1968 wiring question 68SoBe Electrical & Wiring 5 Nov 23rd, 04 12:46 PM
MSD tach adapter question camaro-69ss Electrical & Wiring 4 May 25th, 02 12:30 PM
