another backup light question - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 5th, 07, 05:02 PM Thread Starter
I have a 68 with a Muncie M20 and a Competition Plus shifter. After reading the older posts on the forums it sounds like I need the Hurst switch that maybe Ricks sells.
Part #: HCP-7 Description: Hurst Back-Up Light Switch Assembly
Can anyone tell me if this is the right switch and how it mounts, Does anyone have any pictures of this switch or similar ones mounted.
Ray
ray moore is offline
post #2 of 4 (permalink) Old Apr 5th, 07, 05:17 PM
Re: another backup light question
That is the correct switch.
It attaches to the rear "stop bolt" on the shifter, you just take it out, then screw it back in with that bracket on. The locknut will hold the bracket. Adjust the position of the bracket / depth of the switch so the reverse lever pushes in the switch when you're in reverse.
Wires should be pink and green.
post #3 of 4 (permalink) Old Apr 5th, 07, 05:55 PM Thread Starter
Thanks Jim.
I'm looking at pic's I took of my shifter and after your explanation I think I see how it installs. I see the wiring to the lights and into the trunk. I just need to find where they wind up under the dash somewhere. Did they originally terminate into a single connector of some kind? I assume they also need to run down the wire harness and into the center console and end up at the switch. I bought one of those nice laminated color coded wiring diagram a year ago when I was working under the dash but cannot find the thing anywhere.
Ray
post #4 of 4 (permalink) Old Apr 5th, 07, 06:20 PM
on a 67 there is a 2 spot connecter on firewall on right on fire wall. look at gas linkage from under hood and you will see it.
jaguareats is offline
Side Marker Light Question South Side Goons & Hitmen Electrical & Wiring 5 Aug 3rd, 06 02:17 PM
67 RS backup light cutouts Indy Z11 Body Shop 7 Jul 27th, 06 09:15 PM
Front Lower Valance Parking Light Lens Question?? Chuck L Restoration Corner 6 Feb 4th, 06 05:27 PM
Backup Light Harness Question wishbone Electrical & Wiring 3 May 3rd, 05 12:32 PM
parking light question 61z28 Electrical & Wiring 1 Jul 23rd, 04 07:22 AM
