Starter wiring and hei ignition wiring - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 16th, 07, 02:42 PM Thread Starter
Hi
I have two questions. I have a 383 66 el camino I know its not a camaro but I got it for free. I am trying to wire up the starter and a hei ignition and found the wires were cut.
1 How can id the starter wire. ex switched hot goes to what on the starter. And other wires to the starter?
2 Also I installed a hei ignition and the wires were also cut. What wires do I put to the hei, and how do I id the tach wire to the hei?
Thanks for any help on this matter.
Jerryt
jerryt is offline
post #2 of 8 (permalink) Old Apr 16th, 07, 03:06 PM
Re: Starter wiring and hei ignition wiring
Since you're using an HEI the only wires you need on the starter are the positive battery cable on the center post and the purple 12 gauge wire on the small post closest to the engine. As for the HEI I'd just run a 12 gauge wire from the IGN terminal on the fuseblock to the BAT terminal on the HEI. The coil cover should be labeled BAT and TACH. With the terminals facing you the BAT should be on the right and the TACH on the left.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 8 (permalink) Old Apr 16th, 07, 03:07 PM
for the starter, you havd 2 wires in that car (not counting the pos battery cable)
There was a yellow one, which ran only up to the coil, you do not need it with HEI.
The one you do need is purple, and pretty big. It goes to the inner small stud on the starter, closest to the block.
The connections on the HEI are labeled... one is for sure labeled tach, the other is "IGN" or something like that. There are only the 2 connections. Female 1/4" spade connectors will work, though the factory type locking connectors are prefered cause they won't fall off while you're driving down the road.
The original hot wire to the ignition was skinny and covered with a white braided fabric that's probably pretty brown by now. If you can find it, go back to within 6 inches of the big firewall connector, cut it, strip it, and solder on a new 12 gauge stranded wire. (that braid stuff won't handle the hei)
If you can't find it, just make up a new wire, feed it under the dash thru the speedo cable grommet and connect it to the terminal on the fuse box labelled IGN using a 1/4" female spade connector.
post #4 of 8 (permalink) Old Apr 16th, 07, 03:08 PM
lol. ya beat me 12run!
post #5 of 8 (permalink) Old Apr 16th, 07, 05:23 PM Thread Starter
Ok Thanks
1 The purple wire on the starter goes from block side terminal to the post where the battery cable? Or does it go else where?
2 And the tach wire goes from the tach to the hei cap. Correct?
Jerryt
jerryt is offline
post #6 of 8 (permalink) Old Apr 16th, 07, 07:01 PM
You need to test whatever wire you are going to use, be it the replaced resistor wire or one from the fuse box is that it has power in both the crank and run positions. If it doesn't have power in the crank position, using the yellow wire is one way of fixing it. (there are other ways too)
Most of the ones I seen are marked "BAT" for power and "TACH" for the tach
You can get the factory style locking connectors from Jegs. http://www.jegs.com/webapp/wcs/store...0002_760671_-1
If you use the fuse box, be sure to carry extra fuses as the HEI will be fused and if the fuse blows, the car will not run. And remember you can move it to one of the other terminals (ACC or BAT) if there is ever a problem with that circuit (IGN)
Greg U
undee72Z is offline
post #7 of 8 (permalink) Old Apr 16th, 07, 07:11 PM
Originally Posted by jerryt View Post
Ok Thanks
Jerryt
The purple wire comes out of the inboard side of the firewall coinnector, and travels across the firewall in the engine harness, there should be something left of it in there somewhere. It comes from the ignition switch, via the neutral safety switch.
and 2, yes correct.
post #8 of 8 (permalink) Old Apr 17th, 07, 08:18 PM Thread Starter
Talking Re: Starter wiring and hei ignition wiring
Thanks for all the help on my wiring problem. Hope it starts up. Thanks this is a great site.
Jerryt
jerryt is offline
Interesting (I think, anyway) wiring nightmare: HEI and electric fuel pump. 69454 Electrical & Wiring 6 Aug 23rd, 06 01:51 AM
Small Body HEI Wiring? fishin4info Engine 0 Jun 28th, 06 11:59 AM
Wiring help...starter specifically. Brackneyc Electrical & Wiring 2 May 6th, 06 08:33 PM
1967 Camaro 350 Ignition wiring question Mean_Gene3 Engine 6 Oct 2nd, 05 12:50 PM
MSD 6AL Ignition wiring problem Smokey Electrical & Wiring 6 May 2nd, 05 07:43 PM
