Die-electric grease do's and don'ts - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 20th, 07, 12:11 PM Thread Starter
I posted this similar question in the wrong forum! I think it belongs here. My first question was awnsered but now I have another one. When I cleaned up my steering column I placed die-electric grease on the contacts on the turn signal switch. Are these contacts ment to be dry like the cap and rotor of the distributer? What contacts besides bulb sockets and spark plug boots(both ends) should this stuff be applied to???
fearsomfoe is offline
post #2 of 5 (permalink) Old Apr 20th, 07, 01:07 PM
Re: Die-electric grease do's and don'ts
Generally connections subject to moisture. It won't do any harm elsewhere though.
go2fast is offline
post #3 of 5 (permalink) Old Apr 20th, 07, 03:51 PM
Harry
dawg's Avatar
except the rotor and cap contacts lol.
remember a little bit goes a long way
434 stroker
US Navy retired
dawg is offline
post #4 of 5 (permalink) Old Apr 20th, 07, 05:37 PM
Ron
Rust Check Light is great for Smaller Electrical Contacts, Relays and Light Sockets and yes even Rotor Caps. I would use Di-Electric Lithium in major Electrical Connections such as around the Fuse Panel, Battery Junctions and Ground Straps.
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 5 (permalink) Old May 15th, 07, 07:12 PM
Kevin
I agree. The rule is if you can see the grease, you have applied too much. Kevin
kcart55 is offline
