1969 Horn Relay Question - Team Camaro Tech
post #1 of 9 (permalink) Old Apr 21st, 07, 07:27 PM Thread Starter
Cool 1969 Horn Relay Question
I want to bypass my horn relay. What wires do I need to attach so my car will start. Thanks
onewickedcamaro is offline
post #2 of 9 (permalink) Old Apr 22nd, 07, 07:12 AM
Kevin
SixtyAte's Avatar
Re: 1969 Horn Relay Question
Huh???
By pass the horn relay so your car starts ? Ummm you need to give more info as to what , when and WHY? Are you sure that you are not talking about the neutral safety switch? We need more info...
Kev
SixtyAte is offline
post #3 of 9 (permalink) Old Apr 22nd, 07, 11:00 AM Thread Starter
o.k. Lets start here. What does the horn relay do? and what happens if I disconnect the wires going to it? .
post #4 of 9 (permalink) Old Apr 22nd, 07, 12:28 PM
On a '69 the horn relay serves three functions. 1. It's a relay that gets grounded by the horn button to power the horn. 2. It's a buzzer that reminds you your key is in the ignition when you open the door. 3. It's a connection point between the hot wire coming from the battery and the hot wire going to your fuseblock. If you take all the wires off of it everything controlled from inside the car will not work. If you have to bypass it use a small #8 or #10 nut and bolt to join the two 12 gauge wires with forked terminals together. Just make sure they don't touch any sheetmetal or zap!
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #5 of 9 (permalink) Old Apr 22nd, 07, 12:29 PM
madmax87's Avatar
Your best bet would be to look at the sticky at the top of this topic (Electrical Basics). It will show you everything that runs through the horn relay. Then you can decide from there if its worth removing. Myself, I would leave it in.
madmax87 is offline
post #6 of 9 (permalink) Old Apr 22nd, 07, 03:00 PM Thread Starter
Thanks for the info.
post #7 of 9 (permalink) Old Apr 22nd, 07, 05:22 PM
The two red wires on the buss bar are from the battery and to the rest of the car. Take one wire off and put it on top of the other wire.
post #8 of 9 (permalink) Old Apr 22nd, 07, 05:52 PM
I can't imagine why you would want to take the wires off the horn relay. If you do, you'll have to find an alternative buss bar. The horn relay does that job pretty well.
dnult is offline
post #9 of 9 (permalink) Old Apr 23rd, 07, 02:03 AM
Brad
Great reading here:
http://www.madelectrical.com/electri...evymain1.shtml
Brad
68 Camaro
squid is offline
69 camaro horn relay upgrade chrisp1 Electrical & Wiring 4 Oct 11th, 06 05:31 PM
67 horn relay bad? GMJoe Electrical & Wiring 0 Jun 12th, 06 02:50 PM
Horn Relay Problem RJD's68 Electrical & Wiring 1 Apr 27th, 06 06:46 AM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 07:53 PM
Help with '68 Wood Steering Wheel Horn Cap Installation on a Tilt column ggkeller Interiors 2 Jun 29th, 05 06:32 PM
