wiper stops in the up position - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 26th, 07, 04:29 PM Thread Starter
Daniel
I figured out my wiring for it but the thing stops with the wipers up, how do I fix that? Also my washer doesn't work, I hear the clunk when the solenoid engages but thats it.
sweetblue69 is offline
post #2 of 2 (permalink) Old Apr 26th, 07, 06:23 PM
Re: wiper stops in the up position
Take the nut or bolt off of the motor shaft, pull the lever off of the shaft and rotate the lever 180 degrees and reinstall the nut or bolt. You should hear a pulsating click for about five seconds after you push the washer button. That's the sound of the washer pump pumping. If you don't hear it pulsing the pump could be bad. Check the screen on the end of the hose in the washer tank. If it's clogged you won't get any squirts. Don't ask me how I know. I learned the hard way.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
Wiper Refills mjs-13 Camaro Tech 5 Oct 27th, 06 05:22 PM
Wiper armature position DREID Electrical & Wiring 7 Jan 26th, 05 09:23 AM
Wiper Motor - Crank position DREID Electrical & Wiring 8 Jan 24th, 05 10:44 AM
Calling all wiper arms! coach420 Body Shop 17 Jun 19th, 02 08:00 AM
Windshield wiper position wendy68 Troubleshooting 1 Nov 4th, 99 05:35 AM
