High Beams don't work - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 26th, 07, 06:16 PM Thread Starter
I have a '67 Camaro RS, I replaced the high beam switch. I turned the high beams on and off several times and they worked fine. A week later they do not work. This is the second time I replaced the switch with the same results. The headlights, parking lights, and turn signals all work fine. Are the reproduction switches no good? Anyone have any ideas as to what the problem may be? Thanks.
GaryL67 is offline
post #2 of 2 (permalink) Old Apr 26th, 07, 07:59 PM
Re: High Beams don't work
first guess would be corroded terminals on the connector for the high beam switch.
Low Beams Out, But High Beams Are Fine SFCamaro Electrical & Wiring 4 Oct 17th, 05 12:17 AM
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
High volume or high pressure edcorsaro Performance 9 Sep 16th, 05 07:46 PM
Oil Pump Info High Volume Myths & Fables Set Straight camaroman7d Engine 21 Apr 16th, 04 03:54 PM
All work and no play 383 Bench Racing 17 Apr 2nd, 04 05:05 PM
