1969 Camaro Headlight's - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 26th, 07, 08:38 PM Thread Starter
Cool 1969 Camaro Headlight's
I just installed all wires from another 1969 camaro.( My camaro did not come with any wires). When I pull the headlight switch the parking lights come on but not the headlights I also noticed that the dash lights are not on , When I step on the high beam switch the headlights come on & the dash lights come on. Also i bought a new brake light switch but the brake lights do not come on when i step on the brakes. One note I bought a new headlight switch also, It is not grounded. But I know it needs to be, I cleaned a spot on some metal and put the switch against it it made no difference, one other thing I do not have the front turn /signal lights hooked up yet. Where do I start looking?
onewickedcamaro is offline
post #2 of 2 (permalink) Old Apr 26th, 07, 10:11 PM
Re: 1969 Camaro Headlight's
Your headlamps are not getting a good enough ground. You need an 8 gauge pigtail running from your negative on your battery to your passenger fender.
and
Brian Lewis is offline
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 10:41 AM
2004 SuperCar Reunion Labor Day weekend HawaiianCamaro Team Camaro Cruiz-Ins 1 Aug 25th, 04 09:51 PM
1969 camaro RS SS GETYOPAPION Tech 2003 4 May 22nd, 03 01:31 PM
1969 FIREBIRD steering box, 1967 & 1968 Camaro KED67 Brakes, Suspension & Steering 2 Jul 1st, 01 06:03 AM
