Third (coil) wire mystery - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 5th, 07, 11:21 AM Thread Starter
Strick
I have three wires feeding to my coil; one positive, one negative and one yellow wire. The yellow wire from my harness that has pulled away from something. It is just hanging there. Where should this go?
The original engine (about to be yanked) is a 250 6 cylinder.
Thanks!
Strick
Strick is offline
post #2 of 5 (permalink) Old Jul 5th, 07, 11:45 AM
Re: Third (coil) wire mystery
I believe the yellow wire goes from the coil positive to the starter solenoid 'R' terminal and provides a full 12v to the coil when the starter solenoid is engaged.
onovakind67 is offline
post #3 of 5 (permalink) Old Jul 5th, 07, 12:07 PM
Yep.
Eric
Eric Kammerer is offline
post #4 of 5 (permalink) Old Jul 5th, 07, 12:15 PM
Smile Re: Third (coil) wire mystery
This yellow wire was used on ignition systems that used points. The optical and electronic systems (Unilite, Pertronix, etc.) do not require this yellow wire. It's purpose is to supply 12 volts to the coil while cranking. It was originally used with systems that had the resistor wire running from the bulkhead connector/fuse panel to the coil.
Do a little research here and you will find this topic covered extensively.
68 Coupe, 350, M20 frame off restoration (a work in progress).
ironhorse78247 is offline
post #5 of 5 (permalink) Old Jul 5th, 07, 12:35 PM Thread Starter
Strick
Thanks guys! I guess on my new motor (MSD ignition) I won't be using it.
Strick
Strick is offline
The pink/black strip coil wire rickhunter1max Electrical & Wiring 0 Nov 24th, 05 04:04 PM
msd 6AL coil wire stacy Electrical & Wiring 0 Nov 8th, 03 04:46 AM
super coil bruce69camaro Tech 2000 3 Sep 28th, 00 05:59 AM
Resister wire for coil weaverdb Electrical & Wiring 3 Mar 27th, 00 09:02 AM
