Ignition Control Module Wiring Diagram - Team Camaro Tech
post #1 of 1 (permalink) Old Jul 15th, 07, 12:05 PM Thread Starter
Thomas
Does anyone have the ignition control module wiring diagram that shows the Camshaft Position Sensor Signal wire running from the ignition control module to the PCM? I need to know exact what circuit that wire runs to. Does it run to the C1 or C2 circuit, and at what cavity pin. This is for a 98 Camaro with a 3.8 V-6 engine and 4L60E automatic trans. If you can't post it here, you may email me at: [email protected] Thank you very much for your support, Tommy.
CamaroV-6 is offline
1968 Ignition Wiring HELP!!!! cDuck28Z Electrical & Wiring 4 Nov 23rd, 12 04:51 PM
67 Radio Wiring Diagram BonnieJ Interiors 2 Jun 13th, 07 01:39 PM
99 Wiring Diagram Power Door Lock DONZIGW Electrical & Wiring 1 Aug 16th, 05 10:59 PM
67 RS head light wiring diagram 67TahoeRS Electrical & Wiring 3 Jul 1st, 05 09:38 AM
MSD 6AL Ignition wiring problem Smokey Electrical & Wiring 6 May 2nd, 05 06:43 PM
