1 Wire Starter Troubles - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 30th, 07, 06:54 PM Thread Starter
I installed a 1 wire hi torque starter to replace my 2 wire stock starter. I have the positive battery cable connected to the starter, a good ground from the battery to the engine block and have 11.82 volts at the purple ignition when the key is turned to start - then what could I be missing??
Any ideas appreciated - Thanks
Countryside_Cafe is offline
post #2 of 4 (permalink) Old Jul 30th, 07, 06:56 PM
Re: 1 Wire Starter Troubles
If you have all 3, you have a bad starter if it doesn't crank over, or at least try to..
post #3 of 4 (permalink) Old Jul 30th, 07, 07:20 PM Thread Starter
OK thanks. At first I thought I eliminated the wrong wire going from 2 wire to 1, but the the one I eliminated only went from the the second wire terminal to the coil. I will connect the old starter an try that.
post #4 of 4 (permalink) Old Aug 2nd, 07, 05:07 AM
How did you make out? I may be doing this same project on friday.
Dave69Z is offline
