Headlight Problem - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 2nd, 07, 02:28 PM Thread Starter
Send a message via AIM to Dwight's Z/28
Headlight Problem
Hi Folks,
Thought I'd start with you all, before I started digging in to what my problem is....
Basically... Just recently the headlights on the car are not activating for me. It appears that all other lights are fine (Braking, Turn signal, Parking, etc.) Any quick and dirty advice anyone can offer to help me get a running start to try and solve this problem would be greatly appreciated.
1969 Camaro X77D80, Lemans Blue, Black Racing Stripes, Black Interior - *He who is taught only by himself, has a fool for a Master.*
Dwight's Z/28 is offline
post #2 of 7 (permalink) Old Aug 2nd, 07, 05:48 PM
Re: Headlight Problem
most likely the dimmer switch, possibly the headlight switch.
post #3 of 7 (permalink) Old Aug 2nd, 07, 06:10 PM
Check your negative to passenger fender ground, without it its very possible your headlights won't turn on.
and
Brian Lewis is offline
post #4 of 7 (permalink) Old Aug 2nd, 07, 06:19 PM
Tony
Send a message via AIM to tony -Di
just a thought did you ck the bulbs
tony -Di is offline
post #5 of 7 (permalink) Old Aug 2nd, 07, 07:09 PM
bill
too all above . also do you have a standard or rs headlight system. just a thought here for now.
hereitis67 is offline
post #6 of 7 (permalink) Old Aug 3rd, 07, 10:57 AM Thread Starter
Thanks guys for the great suggestions. JimM, you bring up an interesting point.... The first time this happened, I hit the high beam switch and it suddenly flipped on the high beams, then would flip to low beams.... second time it happened, the high beam switch wouldn't help my situation. The dimmer switch for the dash appears to be in working order and as I said, the parking lights seem to work fine. You guys gave me a great start and I thank you. Any more help would be greatly appreciated since I know very little about electrical.......
post #7 of 7 (permalink) Old Aug 3rd, 07, 12:01 PM
click's Avatar
replace that hi beam switch on the floor board just for the heck of it anyway. Thats a bad area, your foot hits the connector alot, dirt and moisture are all over the floor area and contacts get dirty and corroded too. Its a cheap replacement item, and probably due anyway. It might be the culprit
click is offline
