not starting - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 22nd, 07, 05:37 PM Thread Starter
not starting
Hello. Just installed 502 in 67. Trying to get it started. Have GM HEI with BAT wire connected to the spade terminal on the Ignition spot on fuse block with nee 12 gauge wire. I have a brand new optima battery. When I go to run position the electric fuel pump kicks on and then when I go to crank nothing happens including the fuel pump goes off. I measured voltage at the HEI connector and it has 11.8 -11.9 volts but when I go to crank it drops to 3 volts. I am confused.
96 Z-28 vert
67 Coupe 502BBC TH400
badzboy11 is offline
post #2 of 3 (permalink) Old Sep 22nd, 07, 11:29 PM
Re: not starting
The IGN terminal at fuse box might not have power in the crank position. Disconnect everything from that terminal, hold key on crank position and check if it has power. if it shows 12v but drops to 3 when cranking, you have a poor connection somewhere.
Greg U
undee72Z is offline
post #3 of 3 (permalink) Old Sep 23rd, 07, 04:52 PM
Re: not starting
IGN should be hot in crank and run. ACC is only hot in the accessory and run positions - not crank. So first off, be sure you are in fact hooked to an IGN source. Second, I believe I've heard folks talk about 67 ignition switches not having a hot IGN in the crank position. My 68 IGN is hot during crank.
dnult is offline
