Red, Green and Purple - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 23rd, 07, 01:52 PM Thread Starter
Steven
These are the three color leads from by rear power window motor.
I was told that you can hook up a 9v battery to move the window up and down.
I don't know which lead needs the power. When I put the battery wire in either the green or purple and ground to the frame I get a spark. When I hook the center red to the positive on the battery and the negitive to either the green or purple...nothing.
This happens on either side so I doubt that the motors are shot, but it's possible.
By the way, I found an old soup can in the regulator mechanism, I've actually seen this before on my old 67.
Any suggestions???
1968 Rally Sport
Corvette Bronze, 327, M-20 4 Spd
PW, PB, AC, Deluxe Int, Vigilite
Norcoastal is offline
post #2 of 6 (permalink) Old Sep 23rd, 07, 04:44 PM
madmax87's Avatar
Re: Red, Green and Purple
I would be very surprised if a 9V battery could drive a window motor. Especially if the window is still in the door.
madmax87 is offline
post #3 of 6 (permalink) Old Sep 23rd, 07, 06:02 PM Thread Starter
Steven
That's what I was told on another post.
1968 Rally Sport
post #4 of 6 (permalink) Old Sep 23rd, 07, 06:37 PM
My '69 motors have only 2 terminals going to them. I tried a 9V on an old motor and it did not work(sparked yes, but the motor did not turn). 12 V battery - to the frame and + to one of the terminals and the motor rotates one direction, + to the other terminal and the direction changes.
Are the 3 wires at the switch? if so the red is battery + feed and the other 2 are to the motor one for each direction. Try a full 12V to ground and either the green or purple terminal.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #5 of 6 (permalink) Old Sep 24th, 07, 03:01 PM Thread Starter
Steven
I'll give it a try and let you know how it goes.
Thanks for the advice.
1968 Rally Sport
post #6 of 6 (permalink) Old Sep 24th, 07, 08:07 PM Thread Starter
Steven
It worked!
1968 Rally Sport
