1 wire alt - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 25th, 07, 09:35 PM Thread Starter
1 wire alt
I have a 67 camaro 1 wire alt. does the clip have to be plug in to the alt to work or can I leave it unplug
smokey1010 is offline
post #2 of 5 (permalink) Old Sep 25th, 07, 10:59 PM
Re: 1 wire alt
If you really have a one wire alternator, you only need one wire, the red one
400bird is offline
post #3 of 5 (permalink) Old Sep 26th, 07, 05:52 PM
bill
Re: 1 wire alt
if it is a 1 wire alt and you plug it in. you blow out the alt with the key on.usually when a alt company does 1 they put a plug over the other 2 prongs so no one can plug it in on mistake.
hereitis67 is offline
post #4 of 5 (permalink) Old Sep 26th, 07, 07:09 PM
Charlie
Re: 1 wire alt
Smokey, what clip are you referring to? The firewall clip or the wire that would normally clip on a standard internal regulator type alternator? IMO the one wire alternators are really not worth it to me. They only begin to charge when you reach a certain rpm, usually 1000rpm. If you have any kind of aftermarket stereo with amps then you are going to experience problems. The don't want to charge at idle. Just my opinion. You may have better luck than me.
67CamaroRS/SS is offline
post #5 of 5 (permalink) Old Sep 27th, 07, 02:03 AM
Re: 1 wire alt
Some 1 wire alternators are truely one wire only, others (like some models of Powermaster) can be 1 or 3 wired. Really depends on who made the alternator.
Greg U
undee72Z is offline
