Added HEI-Now Engine Won't Turn Off! - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 26th, 07, 06:56 PM Thread Starter
I recently added HEI to a '73 Nova that I am working on. I used the original resistance ignition wire to trip a relay. The power supply to the relay is a 12 gauge wire directly from the battery, and then another 12 gauge wire to the HEI.
When I turn the ignition off, somehow there is voltage back feeding to the HEI from the ignition wire. With the ignition switch turned off, the engine just keeps on running.
The only way I can turn it off is to pull the ignition 12V+ wire off of the relay, and then the motor shuts off.
I have read on this site previously about having to add some type of resistor, or some other Radio Shack provided piece of equipment (diode?) to fix this issue.
Can someone please tell me what I need to do to fix this? Thanks very much!
1969 383CI, T-56, 12 bolt-3.31 posi, 13" C5 Rotors, PBR Calipers, rear disc system..
Go69 is offline
post #2 of 9 (permalink) Old Sep 26th, 07, 07:05 PM
Charlie
Re: Added HEI-Now Engine Won't Turn Off!
HEI does not use the resistance wire.
67CamaroRS/SS is offline
post #3 of 9 (permalink) Old Sep 26th, 07, 09:17 PM
Strick
http://www.msdignition.com/pdf/6%20series/6series.pdf
Read page 8 of 24 in the pdf file.
It explains it well, as well as the fix.
Strick
Strick is offline
post #4 of 9 (permalink) Old Sep 27th, 07, 12:54 AM
he is using the resistor wire to trigger a relay that powers the HEI.
seems like a good way to get max power to the coil.
i can't see how the current going thru the power wire from the battery could keep the car running, unless the alternator power feed is somehow on the same side of the relay as the coil.
you don't plan sincerity.
novaderrik is offline
post #5 of 9 (permalink) Old Sep 27th, 07, 02:08 AM
Most likely power from the GEN lamp is keeping the relay closed and causing the engine not to turn off. You need to add a diode. See the link Strick posted.
Greg U
undee72Z is offline
post #6 of 9 (permalink) Old Sep 27th, 07, 05:54 AM
Bruno
Or an electric cooling fan, generating enough power to...
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #7 of 9 (permalink) Old Sep 27th, 07, 01:25 PM Thread Starter
Thanks everyone for the input.
To clarify-the car does not have an electric fan. The gen lamp wire from the alternator is the problem based on the information found on page 8 of that MSD instruction sheet. Thanks Strick! This cars alternator is internally regulated, so the wire coming from the alt. is the one that gets the diode.
Now the next question, does anyone know what type, color, size, wattage diode that is needed? I would like to head over to Radio Shack to see if I can pick one up.
Thanks again for the FAST & informative responses!
Go69 is offline
post #8 of 9 (permalink) Old Sep 27th, 07, 01:33 PM Thread Starter
Okay, disregard the request for info on the Diode. It is CLEARLY written on that diagram from the MSD web site. I just needed to slow down, and read what was in front of me.
This site remains, as it always was before, the very best.
Thanks again everyone for your time and effort.
Go69 is offline
post #9 of 9 (permalink) Old Oct 5th, 07, 11:23 AM
Steven
stamatisg1977's Avatar
my engine has run on too. i have the e-curve distributor but it did not come with a resistor. do i need one for my type of distributor?
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
