Need help with alternator - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 27th, 07, 07:33 PM Thread Starter
jsouthco68camaro's Avatar
I recently replaced my alternator because it was draining the battery as the car sat in the garage. It was a one wire set up.
I went to checker, told them the car I had and got a new alternator. I hooked the one wire up the same as it was on the previous and I am getting no charge..(I tried checking at higher rpm as well.) I measured the voltage at the battery and also between the neg post and the rear post of the alt.. They both showed only 12.5v and very slowly increased by .01v as the car ran....
Could i have bought an alternator that doesnt support the one wire? Does the alternator need to be grounded somehow?
I could sure use some help on this..
1968 Camaro
350 / 4 spd
Then.....
Now....
jsouthco68camaro is offline
post #2 of 11 (permalink) Old Sep 27th, 07, 07:39 PM
Re: Need help with alternator
If you asked for an alternator for a 68 camaro, you probably got one that needs an external regulator!
Is there a connector on the alternator, beside the big stud for the red wire?
Can you post a pic of the back of it?
post #3 of 11 (permalink) Old Sep 27th, 07, 08:06 PM Thread Starter
The alternator i got does have a plug on the back.I will post a pic - Please let me know what you think.. If I need to get a different alternator, please let me know what i need to ask for..
Thanks- Jim
1968 Camaro
350 / 4 spd
Then.....
Now....
post #4 of 11 (permalink) Old Sep 27th, 07, 09:04 PM
yup, that's an original style alternator for a 68, it needs an external regulator.
Sorry, other than checking powermaster on Summit, I'm no help on a parts store application for a 1 wire.
post #5 of 11 (permalink) Old Sep 28th, 07, 04:44 AM
What other wire & their color do you have available to hook up to the alt?
Is the ext regulator wiring gone or replaced with another hook-up?
post #6 of 11 (permalink) Old Sep 28th, 07, 07:49 AM
Charlie
IMO I would use an alternator that uses a standard type regulator and not a one wire set-up. One wire alternators don't start charging until you hit a set RPM. Usually around 1000. So that means that when you are idling at a light you are not receiving any output from the alt. They are nice for hotrods because they like the "LESS WIRE" look. They make high power standard type alt's. Right now I have a 250amp alt that uses the CS144 wiring.
http://www.nationsautoelectric.com/e...ternators.html
67CamaroRS/SS is offline
post #7 of 11 (permalink) Old Sep 28th, 07, 08:08 AM
From the Nations site:
Alternators produce AC current, just like the
current from your house wall outlet. Then it
uses a bridge rectifier, typically with six
diodes to convert AC current to DC to send to
the battery. With Dual Rectifiers, you get 12
Diodes, which spreads the load over a much
larger area making the alternator twice as
durable and twice as efficient.
The benefits
include: less heat, less current loss, higher
amperage when hot, more power at idle.
How does dual rectifiers make the alternator twice as efficient?
onovakind67 is offline
post #8 of 11 (permalink) Old Sep 28th, 07, 08:17 AM
It really doesn't seem like it would make them more efficient. It may make it possible for them to produce more current simply because each diode would only have to handle 1/2 the current they would otherwise. The so-called efficiency improvement comes from reduced power dissipation by the diodes. The diodes drop about 0.6 volts each. If you pull 100 amps from the alternator, each diode disipates 60 watts. By doubling the diode count, each diode disipates 30 watts. (Actually the power disipation isn't this straight forward since the alternator is a 3-phase device, but the halving of power still applies). All in all, you're still disipating the same power, but it's spread out over a wider area, it's easier to disipate the heat, and theoricially the alternator can produce more current as a result. But in reality, it isn't more efficient.
dnult is offline
post #9 of 11 (permalink) Old Sep 28th, 07, 08:40 AM
Originally Posted by onovakind67 View Post
The benefits
It ain't gonna happen.
All they have done is paralleled another diode per existing diode. Due to manufacturing tolerances, the one diode of the pair will conduct first and be the first to conduct to max current by the external load.
Then, the second diode of the pair will conduct. But both diodes do not conduct equally, one is always working more than the other.
post #10 of 11 (permalink) Old Sep 28th, 07, 01:41 PM
Fred
Here's how I got around the heat problem on my sailboat alternator. Just removed and replaced the rectifier with a set from a large frame (ambulance) alternator, then rigged a two speed squirrel cage blower in the back for cooling. The green wires come from the alternator stator.
128.79mph 1.428 60'
Fred Ficarra is offline
post #11 of 11 (permalink) Old Sep 28th, 07, 01:55 PM
Charlie
I know that I can have my heater on full blast, my wipers on full, headlights on, and my VERY VERY VERY high power stereo going at VERY HIGH OUTPUT and my alternator doesn't flinch off 14.4volts. I have no complaints about my alternator that I got from Nations. I had a PowerMaster 100amp unit and it was junk. It couldn't handle my stereo at all. When I had my lights on, the radio, and the stereo on the PowerMaster alternator couldn't hold up. It was a waste of money.
