Dome & Courtesy light problem - Team Camaro Tech
post #1 of 11 (permalink) Old Oct 1st, 07, 04:36 PM Thread Starter
Rick
Getting close to the finish of restoration on my 69 Z28. Hooked battery up today to check all electrical. Seems everythings fine except the dome and courtesy lights will not go off. Disconected both door jamb switches with no change. Can there be any other problem except the headlight switch? It works the headlights fine and will dim the dash lights. Also does click when turned completely to the left in the position to turn the courtesy and dome light on. Help!
othal is offline
post #2 of 11 (permalink) Old Oct 1st, 07, 05:05 PM
Re: Dome & Courtesy light problem
Well, disconnect the plug on the headlight switch and see if they go off?
At it's most basic, you're problem is a ground on the white wire.
One would hope it was happening at one of the 3 switches (2 door and the headlight switch) but it could be anywhere.
post #3 of 11 (permalink) Old Oct 1st, 07, 05:27 PM Thread Starter
Rick
Jim if I unplug the plug from the switch are you saying that if the lights go out then the problem has to be in the switch and if they stay on that it probably is a ground?
othal is offline
post #4 of 11 (permalink) Old Oct 1st, 07, 05:49 PM
bill
yes all interior lights get positves all the time. when you open door or turn on headlight switch it provides ground to the lights. or a wire somewhere is grounded in the circuit.
hereitis67 is offline
post #5 of 11 (permalink) Old Oct 1st, 07, 06:10 PM
yes
Tho one would hope not, it could be a place anywhere on that white wire where the insulation got nicked and it's grounding out. Most likely tho, it's one of the 3 switches. How did you test the door switches? Did you take the wires off the back (real hard to reach!)? or unscrew the switch from the door?
Do you have only the roof light, or do you have underdash lights or a console light?
post #6 of 11 (permalink) Old Oct 1st, 07, 07:02 PM Thread Starter
Rick
I have roof and underdash lights no console. I unscrewed the doorjamb switches,pulled them out and then disconnected the wires frmthe back.
othal is offline
post #7 of 11 (permalink) Old Oct 1st, 07, 11:44 PM
Bobby
i had a problem like that. i installed a reproduction lamp housing and the light stays on, even with the doors closed. i had to put some ul tape up above the housing.
69 Camaro Z/28 Rally Sport 10A of 68. 50 S with 723 int. .040 over 302 with m22 autogear wide ratio. BU 12 bolt posi.
69CamaroRT is offline
post #8 of 11 (permalink) Old Oct 2nd, 07, 08:18 AM
Strick
JimM, on my vert the courtesy lights were not hooked up when I bought it. The jam switches are in, but the socket on the passenger side just hangs there. I can't seem to find the drivers side bulb socket.
A couple of questions: Does the grounding take place when the socket is in the dash keeper? Where does the drivers side socket get placed in (under) the dash?
- Also - I did try hooking up the console courtesy, and it works fine, but will not turn off when the doors are closed.
Thanks!
Strick
Strick is offline
post #9 of 11 (permalink) Old Oct 3rd, 07, 06:31 PM Thread Starter
Rick
I finally found my problem. All three switches were fine. One of the courtesy light sockets was grounded where it goes in the mount. Thanks guys for the help.
othal is offline
post #10 of 11 (permalink) Old Oct 3rd, 07, 08:24 PM
Strick, on the verts (or coupes with the under dash lights) the sockets are part of the accessory courtesy light harness. This is a separate peice that plugs in above the drivers side kick panel and runs across the dash side to side. It contains both sockets and the pass side switch wire. The sockets have 2 wires (orange and white) and are not grounded.
The sockets plug into metal brackets (reproduced) that attach to the lower edge of the dash with a sheet metal screw.
I'm a lil fuzzy on where the pass side switch wire on a coupe comes from, I only do topless!
post #11 of 11 (permalink) Old Oct 3rd, 07, 08:36 PM
Strick
DUDE................................I am topless guy too!
Thanks for the info! I did find the drivers side socket tucked behind the kick panel. Now to find out why they are staying 'ON'.
Strick
Strick is offline
