Hot Dome Light - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 3rd, 07, 09:29 AM Thread Starter
Hot Dome Light
I've had an ongoing problem with the dome light bulb being too hot for the replacement receptacle and I've had to remove the bulb to prevent discoloring or melting the light. I've recently found an LED bulb that is a direct replacement and burns without excessive heat. Anyone with this problem, go to "www.ledlight.com"....they have LED replacements for virtually every bulb.
Hope this is helpful to someone....I've gotten great information from Team Camaro and haven't been able to give much in return.
Sam
68SS396
severasw is offline
post #2 of 6 (permalink) Old Oct 3rd, 07, 09:57 PM
Re: Hot Dome Light
No, actually its quite common to have issues with the dome light melting when the door is left open. I run an LED from superbrightleds.com
Some people complain that it's not bright enough, but I don't mind it. I think of it more like mood lighting!
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #3 of 6 (permalink) Old Oct 4th, 07, 02:24 AM
Re: Hot Dome Light
If you use LEDs, especially bulbs that fit into the factory socket take note that they are polarity sensitive, and this can happen if plugged in or wired the wrong way http://www.chevelles.com/forums/showthread.php?t=191855
Greg U
undee72Z is offline
post #4 of 6 (permalink) Old Oct 4th, 07, 09:07 AM
DjD
DjD's Avatar
Re: Hot Dome Light
A Diode is a one way device, it only passes the batt in one direction and blocks it from getting to ground and completing the circuit if batt is applied to the wrong side. With an LED plugged in backwards it won't light up. It doesn't short the hot lead out though and cause the problem in that Chevelle thread.
...Dennis
DjD is offline
post #5 of 6 (permalink) Old Oct 4th, 07, 09:42 AM
Re: Hot Dome Light
LED's are not your usual diodes. The forward voltage drop is 2 to 4 times the drop across a standard silicon diode, and the peak inverse voltage is unusually low, normally less than 6 volts. Putting 12v of reverse bias could be fatal.
http://www.vias.org/feee/diode_11_03.html
onovakind67 is offline
post #6 of 6 (permalink) Old Oct 5th, 07, 09:16 AM
Christropher
Re: Hot Dome Light
Check out the dome light thread from Brian Lewis:
https://www.camaros.net/forums/showthread.php?t=81748
Christropher
...in pieces still.
clwilcox33 is offline
