LED lights and DSE Motors - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 4th, 07, 07:05 AM Thread Starter
We just put in the DSE RS motors on my 69 RS. Everything was working fine. Then we noticed that one of the LED boards in my tail lights on driver side was on. Pulled fuse on motors and put back in. Motors cycled one time and everything seemed to be ok. Moved car and a different LED board on opposite side was on. When this happens the motors will not operate but all the lights are on. Everything is wired as per instructions. Anyone have any ideas what the problem is??
502prostreet is offline
post #2 of 4 (permalink) Old Oct 5th, 07, 05:23 PM
Re: LED lights and DSE Motors
you headlight motors are affecting you tail lights?
Thats one crazy problem, I would start checking the grouds
400bird is offline
post #3 of 4 (permalink) Old Oct 9th, 07, 05:18 PM
I just put the same kit on my 69 RS. I would double check your conn. on the back of your headlight switch harness. The park lights run thru the DSE module. If you turn on your park lights your headlight doors will stay closed until you turn on your headlights. But when you turn off your headlights and leave your park lights on your doors will remain open until you turn off your park lights. This is so you can clean your headlights without them being on. I suspect that the wires that you have to jump on the harness at the back of the headlight switch is where the problem is most likley.
Cameromike is offline
post #4 of 4 (permalink) Old Oct 15th, 07, 07:54 AM Thread Starter
We talked to Mark at DSE and everyone has come to the conclusion that the module that goes under the dash is the culprit. We will also double check the wiring again.
Thanks guys.
