electrical polterguist 1971 ss/rs - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 8th, 07, 07:12 PM Thread Starter
doug
Question electrical polterguist 1971 ss/rs
Rear passenger side back lamp brighter than the rear drivers side lamp. With headlights/light switch on
drivers side rear blinker works, rear passenger side blicker does not. With lights off both blinkers work.
Rear passenger brake light glows dimmer than driversside brake light ????
69' SS 396 L78/468 /71' RS/SS 4 spd nev silver/66' SS L78 triple blk chevelle sold
dougie fresh is offline
post #2 of 4 (permalink) Old Oct 9th, 07, 05:43 AM
MARK
Send a message via AIM to PROZ11
Re: electrical polterguist 1971 ss/rs
Sounds like a grounding problem. I'd check there first. Make sure you have good contact at the ground(s).
Pro Street Z11 clone
YOUTUBE VIDEO:
PROZ11 is offline
post #3 of 4 (permalink) Old Oct 9th, 07, 06:01 AM Thread Starter
doug
Thanks. Where are all the grounds?
post #4 of 4 (permalink) Old Oct 9th, 07, 03:18 PM
Not sure exactly where the grounds are on your 71, but there is an easy way to check the condition of your grounds. Since the problem seems to be in the rear, get a digital volt-ohm meter and measure between the tail panel (or other grounded surface near the lamps) and the negative battery post. You'll probably need a piece of wire, a jumper cable, or an extension cord to "stretch" you meter lead so it will reach. You should see a very slight reading on your DVM (less than 0.05 volts or so). Then turn on the head lamps and see if the reading changes. If it does repeat your test between the negative post and the right front fender. If you see similar readings check the ground lead from the negative post to the fender. If the readings are different, you may have a ground issue between chasis panels and / or the frame. Grounds can be difficult to track down, but the DVM trick should help you narrow it down. Other grounds to check would be the under-dash area, steering column, etc.
dnult is offline
