Temp Sending Unit Problems - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 19th, 07, 10:20 AM Thread Starter
Crate Motor Has 3/8 Npt Hole In Head. Factory 1967 With Gauges Temp Sender Is 1/2 Npt. Need 3/8 Npt Sending Unit What Will Work With Factory Gauge. Has Anyone Found The The Right Sender. Wells Says To Use Part #no Tu-66 Which Is Off A Little On The Resitance.
Steven D Brown is offline
post #2 of 4 (permalink) Old Oct 19th, 07, 08:05 PM
Re: Temp Sending Unit Problems
Why not use an adapter?
go2fast is offline
post #3 of 4 (permalink) Old Oct 19th, 07, 10:39 PM
I have used an adapter many times for senders that are different size from the opening. Gauges always worked fine
realtime is offline
post #4 of 4 (permalink) Old Oct 20th, 07, 07:43 AM
You really don't want an adapter that "goes down" in size. It would have to stick out several inches, and the head of the sender would be far away from flowing coolant.
How much is the resistance of the sender you found off?
I'd say try it and see how it works. This is a question that has come up a bunch of times, and I don't ever recall seeing a full and satisfactory answer. If that sender proves to be one, I'd love to include the info in the electrical sticky's.
