Center Dash Fuel Gauge - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 28th, 07, 07:10 PM Thread Starter
Does anyone happen to have a few pictures of a Center Fuel Gauge??
I am thinking of installing one. My dash cluster has a tach and I definitely don't have the pesos for console gauges...
thanks
-Aaron
aaron9252 is offline
post #2 of 4 (permalink) Old Oct 28th, 07, 07:30 PM
Re: Center Dash Fuel Gauge
Aaron -
Easiest way is to go to ebay and look at the 69s for sale. There are quite a few on the ones on right now that have the center fuel gauge.
If that doesn't get you what you need, I can shoot one of mine and post it in the morning. If you don't currently have any fuel gauge, and don't want to do the console gauges (I don't blame you there...they're expensive, and they were hard to read in 1969 and they remain hard to read today ), it seems like a no brainer that you have to do the center gauge.
You'll have to cut your center panel out if it's one of the fixed ones, but that's no big deal. The gauge, bezel, and two little clips at the top that hold the top of the bezel are all reproduced now, so it's pretty simple.
If you still have your original fuel gauge, you can use the terminals and resistor off that on the center gauge (it comes without).
Eric
Eric Kammerer is offline
post #3 of 4 (permalink) Old Oct 28th, 07, 07:45 PM
Andrew
Andrew69's Avatar
Here you go.
Name:	Misc Z Photos 027.jpg
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 4 (permalink) Old Oct 29th, 07, 06:46 PM Thread Starter
Eric,
Thanks for the info. I actually have two dash bezels, one with the center cut and another with it closed. I think I am going to go with the fuel gauge in the center...
thanks X33 for the pic.
