what would be the minimal wiring required for first start-up of engine? - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 2nd, 07, 09:16 AM Thread Starter
Rob
RockinRob's Avatar
I'd like to get the motor fired up this weekend, but im not ready to wire the entire car yet.
What would be the necessities in order to do the initial start-up of the crate motor?
I have the AAW classic update wiring package.
I still need to do some work/painting/welding on the dash and interior areas, so i was trying to get by without installing the entire wiring package.
Can i do this with just the battery, wires for HEI, alternator and ignition switch?
Any help or input would be great.
Thanks,
Rob
67 base convertible, GMPP 350/330 HO, TKO500....
Taken around the block for the first time 12/2/07
Finaly getting some paint Sept. 2009
RockinRob is offline
post #2 of 12 (permalink) Old Nov 2nd, 07, 09:26 AM
Re: what would be the minimal wiring required for first start-up of engine?
A battery, battery cables, a length of 12 ga. wire, and a screwdriver.
Hook up battery as normal, run 12 ga wire from positive battery post to HEI terminal labelled "BAT", and use screwdriver across solenoid terminals S & positive bat cable, to crank engine. Add fuel first.
post #3 of 12 (permalink) Old Nov 2nd, 07, 09:54 AM Thread Starter
Rob
RockinRob's Avatar
Do i need to have the alternator hooked up for any reason?
I would assume the battery would be sufficient to run the HEI for 30minutes or so?
Does a remote starter trigger does the same as the screwdriver? It's just a "touch and go" kind of thing to turn the starter over right?
Thanks for the quick respponse.
Rob
post #4 of 12 (permalink) Old Nov 2nd, 07, 10:41 AM
Ron
If you can't drive it yet or properly break it in (if needed) what's the hurry? Take your time, get everything ready. Then when you do start it, you get to go driving also. Unless you just gotta hear it.
rontoomanyprojects is offline
post #5 of 12 (permalink) Old Nov 2nd, 07, 12:10 PM Thread Starter
Rob
RockinRob's Avatar
Ron, not only would i like to hear it, but i will soon be forced to vacate the current shop where it is stored and lose all the ameneties it has. So i'd like to get it fired up for the initial start-up and break-in for the cam. I can then make sure everything is right with the driveline and such before i need to move it back to my garage, where there is little to no room to actually work on it comfortablly.
plus, i would still like to hear it.
Rob
post #6 of 12 (permalink) Old Nov 2nd, 07, 02:43 PM
Robert
I'd want a tach, oil pressure and water temp gauges before I attemped to start it.
Robert
TC member #18
rojo is offline
post #7 of 12 (permalink) Old Nov 2nd, 07, 06:49 PM Thread Starter
Rob
RockinRob's Avatar
i have the temp, and oil pressure gauges i will be installing prior. the tach i doo not have, but will use the timing light for that.
Rob
post #8 of 12 (permalink) Old Nov 2nd, 07, 08:08 PM
BonzoHansen's Avatar
Break-in? If it has to run for 30 mintes I hope your battery can keep up with no alt.
TC Member #13
BonzoHansen is offline
post #9 of 12 (permalink) Old Nov 3rd, 07, 09:23 AM
I built a fancy little latching relay setup for my car. I'll skip the details and say that it applies 12V to the ignition coil and sends 12V to the starter when you crank it. That's all - nothing more.
dnult is offline
post #10 of 12 (permalink) Old Nov 3rd, 07, 06:57 PM Thread Starter
Rob
RockinRob's Avatar
i do have the alt. installed.
i think i'll research a little more before i do anything. may just wait until i get her all wired up. no use getting antsy and messing something up.
thanks guys,
rob
post #11 of 12 (permalink) Old Nov 3rd, 07, 07:22 PM
Tim
77wolf10.85's Avatar
I run them all the time with no alternator, and with alternators unplugged. I even run mine with the water pump turned off for the first few minutes sometimes on a cold start. You won't hurt it, just babysit it like you are wanting to
A hot batt will run just your HEI an hour easy. Add a fan and electric water pump and you have to head to the barn every 20 -30 minutes or carry a jump with you. Hell, put a charger going on it while you're running, I've done that more times than I can remember.
You're not getting antsy... you're wanting the fruits of your labor.
Tim Smith
77wolf10.85 is offline
post #12 of 12 (permalink) Old Nov 4th, 07, 12:15 PM
I see some others have picked up on the need for instrumentation. My oil pressure read-back is coming from my DVM. Power to the gauges is a good thing which I overlooked, but have covered by other means in my case. Sorry for the short-sighted advice.
You don't technically have to have the charging system working. I just charge my battery up with a portable charger and it'll run fine for quite a while straight off the battery. You can even run with the battery charger connected if your voltage starts to droop too much.
dnult is offline
