Adding a I-Pod/MP3 player - Team Camaro Tech
post #1 of 19 (permalink) Old Nov 6th, 07, 08:05 AM Thread Starter
Anyone know the best way and product to hardwire a I-Pos adapter to an old radio. I have a Kenwood KRC-2007 am/fm cassette player and want to be able to play my I-Pod from it using a hidden wire or jack.
Any suggestions?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #2 of 19 (permalink) Old Nov 6th, 07, 08:24 AM
Matt
Re: Adding a I-Pod/MP3 player
wrong forum, sorry!
mattb71 is offline
post #3 of 19 (permalink) Old Nov 6th, 07, 09:15 AM
Charlie
It can't be done on a radio that has the two shaft with the two knobs. That is the type of radio you have, right? The radio needs an auxilary input wire/feature and the old radios don't offer that feature. You would need a unit that is what is called a DIN style. That is the type that does not have the two shafts. You have to cut out the area of the dash that the two shafts slide through in order to open up the area so the unit can slide in. Some radios have a port right on the front of the unit where you can plug in the wire from the I-pod. Also, you would need the car kit for the I-pod. Call any REPUTABLE car audio business and they can tell you everything you need to do the swap and installation. The most important thing is are you willing to cut into the dash? If not, then you will have to mount it in the glove box, but IMO, if you find someone that is WELL KNOWN they will do a very nice job on the installation. Plus, later on if you decide to go back to the original style, you can always weld in pieces to the dash to return it back to original.
67CamaroRS/SS is offline
post #4 of 19 (permalink) Old Nov 6th, 07, 09:43 AM
Kevin
KevinW's Avatar
Mark, there have been a bunch of discussions on IPODs in 1st gens, try a search.
Kevin
KevinW is offline
post #5 of 19 (permalink) Old Nov 6th, 07, 09:45 AM
BonzoHansen's Avatar
FM Modulator...
TC Member #13
BonzoHansen is offline
post #6 of 19 (permalink) Old Nov 6th, 07, 11:21 AM
Kevin
KevinW's Avatar
Originally Posted by BonzoHansen View Post
FM Modulator...
NOOOO, they suck! But they work if you have nothing else
Kevin
KevinW is offline
post #7 of 19 (permalink) Old Nov 6th, 07, 11:44 AM Thread Starter
Do they all suck? That is the way I was thinking of going. The radio has amp inputs (red & white) can anyhting be done with those?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #8 of 19 (permalink) Old Nov 6th, 07, 12:31 PM
I fabricated a box between the console and the dash and installed a cd den style in the box i made. I textured it with a product called SkS then painted it satin black. The CD player {sony} has a jack in the front so you can just plug in to it with your i-pod. This will work as long as you dont have the factory console gauges. Unless you look real real close you can't tell it's not meant to be that way. I did all this so i didn't have to cut my dash. My buddy wired it so both the factory and new cd player will work with the same speakers. He used some diodes to keep the music from feeding back to the other unit but i can't tell you how he did it with out asking but i do know it worked out great without cutting my dash. I hope this helps
i will try to post some pictures later!!
DDOLES is offline
post #9 of 19 (permalink) Old Nov 6th, 07, 02:00 PM
Kevin
KevinW's Avatar
Mark, finding a hole in the bands can be a challenge and they still drift. The RCA jacks from your radio are preamp OUTS, not in's. They are meant to take the line level outputs from the stereo to the amp. You could add an IPOD RCA adapter to your amp and play it there. But to play it thru your radio, you need aux inputs.
Kevin
KevinW is offline
post #10 of 19 (permalink) Old Nov 6th, 07, 03:07 PM Thread Starter
That is the way to go then. I was thinking of getting an amp anyway to get a little more power. So I should be able to find an amp with rca's in for the IPod. I guess then all I would need is a wire with 2 rca's and a mini jack.
Question when I want to use the Ipod all I would have to do is shut the radio off?
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
post #11 of 19 (permalink) Old Nov 6th, 07, 03:46 PM
Jason
jay'srs/ss's Avatar
If your radio has cd changer controls you can get a aux2car from www.discountcarstereo.com and that way you can hook up a Ipod, MP3 player, etc.
My Cars:
70 Lemans Sport 350 w/ 48k Original Miles!!! SOLD!!!
SOLD!!!
88 Camaro IROC-Z SOLD!!!
SOLD!!!
jay'srs/ss is offline
post #12 of 19 (permalink) Old Nov 6th, 07, 04:58 PM
Classic Industries has Shaft Based Radios that offer AUX INPUT for $169
Monster makes a good FM Modulator, it works pretty darn well in my wife's Buick.
Monster Cable iCarPlay wireless FM mini transmitter/battery charger
Monster iCarPlay plugs into your cigarette lighter and attaches to the dock connector on the bottom of the iPod. It's actually two accessories in one — a battery charger and an FM transmitter. It lets you toggle through eight different FM frequencies, so you're sure to find one that isn't occupied by a broadcast station.
$39 here http://www.techmicro.com/product_p/130409.htm
and
Brian Lewis is offline
post #13 of 19 (permalink) Old Nov 6th, 07, 04:58 PM
Doug
thedugan's Avatar
Send a message via Yahoo to thedugan
Get a stock radio and then, have it converted by http://www.turnswitch.com/radio1.htm
Love it. Works awesome
-Doug
68 RS/SS Conv
67 Coupe
Last edited by thedugan; Nov 6th, 07 at 05:00 PM. Reason: link did not work at first
thedugan is offline
post #14 of 19 (permalink) Old Nov 6th, 07, 06:21 PM
Kevin
KevinW's Avatar
Correct, mini jack to amp rca line level inputs. As to powering the amp, you would need and on/off switch for just the amp, not tied to the radio to do this. To use the radio, you would have to turn both on seperately.
Kevin
KevinW is offline
post #15 of 19 (permalink) Old Nov 6th, 07, 06:32 PM Thread Starter
I have heard good things about this modulator
http://www.circuitcity.com/ssm/Audio...oductDetail.do
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
