68 alternator wiring question - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 8th, 07, 01:12 PM Thread Starter
I have a 68 camaro and i recently bought an alternator off of ebay. I was going to do the 1 wire thing but thought i will just stick with my 3 wire. Well when my new one came it has 3 wires all right but the plug is not the same.
I bought the right plug from baxters but am not sure which wires to connect together?
Just the 2 smaller wires
Tacoma Tom is offline
post #2 of 5 (permalink) Old Nov 9th, 07, 06:42 PM
Charlie
Re: 68 alternator wiring question
If the new alternator has a flat two prong connector then it is an internally regulated alternator. If the alt has a square two wire plug then it is an externally regulated alt.
http://store.summitracing.com/partde...5&autoview=sku
The above link is to an internally regulated alternator.
http://cgi.ebay.com/ebaymotors/GM-DE...QQcmdZViewItem
The above link is to a harness for an externally regulated alternator
67CamaroRS/SS is offline
post #3 of 5 (permalink) Old Nov 10th, 07, 07:24 AM
You can easily convert a camaro to use an internal regulated alternator.
There are 2 articles on how to do it in the basics sticky at the top of the electrical forum.
Short version:
Correctly splice on the pigtail connector for the alternator mentioned above.
remove the regulator connector from the regulator.
Install a jumper wire to connect the top and bottom wires on that connector
Install another jumper to connect the middle 2 wires.
They make a prebuilt connector that will plug into the regulator harness connector and do this. Not sure where to find it tho.
post #4 of 5 (permalink) Old Nov 10th, 07, 09:05 AM
bill
ricks got that harness part number 27555 for 20 bux.
hereitis67 is offline
post #5 of 5 (permalink) Old Nov 11th, 07, 02:44 PM Thread Starter
Thanks guys. I used the conversion info from this site to get it hooked up.
