trunk battery question - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 8th, 07, 04:51 PM Thread Starter
Peter
I am shifting the battery to the trunk and have a question on wiring. I will direct wire the positive to the starter but with the negative can I wire direct to trunk floor or rear chasss rails
Is the ground good enough here or should the negative be wired elswhere closer to the motor ( big block)
Thanks in advance
69aus is offline
post #2 of 12 (permalink) Old Nov 8th, 07, 05:09 PM
Strick
Re: trunk battery question
Thanks in advance
I have always grounded mine to the frame. I take a wire wheel to the frame to get it down to bare metal, us a star washer when mounting the ground wire, and then give it a coat of spray paint. I always make sure that I have the motor grounded to the frame and a ground to the firewall from motor also. Then for a little more certainty, I run a ground from the frame to the firewall.
Strick
Strick is offline
post #3 of 12 (permalink) Old Nov 8th, 07, 05:14 PM
Andy
I have mine bolted to the frame rail and I also have a neg. cable from the front frame rail to the block. Cant have too many grounds. Also if you plan on running the car at the track you will need a batt. cutoff switch mounted on the rear of the car in the positive cable.
67 R/S convertible Nantucket blue deluxe interior orig.
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
2x67rs/ss is offline
post #4 of 12 (permalink) Old Nov 8th, 07, 06:04 PM
Fred
Yep. And I'm kinda,,,,,, OK, anal about grounding. I run a humongous ground cable to the starter, under one of the mounting bolts, all the way from the battery in the trunk.
128.79mph 1.428 60'
Fred Ficarra is offline
post #5 of 12 (permalink) Old Nov 8th, 07, 09:10 PM
Marc
If your going to run on the track you'll also need to put the battery in a sealed box that is vented outside the trunk.
Marc
67 Camaro, 454, TH400, 9" 4.11's
camaro man is offline
post #6 of 12 (permalink) Old Nov 8th, 07, 09:27 PM
gramps68's Avatar
I grounded to the trunk on the rail near the wheel well, and again from the motor to the frame....with the huge 1/0 gauge wire!!
Anything worth doing is worth overdoing...a little's good, more's better, and too much is just enough
68 rs - Van Nuys original - one family car.....which still needs to be finished!
gramps68 is offline
post #7 of 12 (permalink) Old Nov 8th, 07, 09:57 PM
Marc
I grounded my to the trunk pan and have had no problems.
Marc
post #8 of 12 (permalink) Old Nov 9th, 07, 12:31 AM
Fred
Or use a red-top. AGM's are sealed. They can be used upside down. But the switch in the trunk's required. Mine's installed now.
128.79mph 1.428 60'
post #9 of 12 (permalink) Old Nov 9th, 07, 04:57 AM
+1
His and Hers Marina blue 67's
67FamilyFun is offline
post #10 of 12 (permalink) Old Nov 9th, 07, 05:22 AM
Tim
77wolf10.85's Avatar
The frame is much bigger than any old 00 conductor. Having said that...I would prefer to have 00 all the way to my starter. But I just have a short piece of 0 or 01 from batt to frame. Oh no take that back... when I rewired I ran a piece of 10 or 12 gauge to my ignition and relays from B-, in addition to the frame ground.
I would be a little apprehensive if the car didn't have subframe connectors, either jumper front half to back half or run wire all the way.
I thought all the rules said was a battery hold-down device is required. Mine has never been sealed, just clamped down. Never had a tech inspector say a thing about it.
Tim Smith
77wolf10.85 is offline
post #11 of 12 (permalink) Old Nov 9th, 07, 09:02 AM
Strick
Valid point on the subframe connectors. Mine does.
Strick
Strick is offline
post #12 of 12 (permalink) Old Nov 9th, 07, 11:05 PM
Andy
I just automatically assumed frame connectors.
NHRA rulebook 8:1 BATTERIES states all batteries must be securely mounted.Rear firewall.024 steel or .032 aluminum required or sealed poly box vented to outside of body.
That is not the complete rule but a short part of what it says.
