Extra wire - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 19th, 07, 11:45 AM Thread Starter
wayne
Extra wire
I hooked up my tail lights today on my standard 69 Camaro. There was an orange wire plugged into the fuel guage socket. It had a short extension on it with another plug . Anyone know what this orange wire was for, my guess is rear defogger or trunk light ?
69 IN PROGRESS,new trunk floor,new rear frame rails, inner outer wheelwells, floorpan ect.ect.ect. I have
to quit coming here.
together is offline
post #2 of 7 (permalink) Old Nov 19th, 07, 12:26 PM
Re: Extra wire
The license plate light.
Don't remember it being orange tho, or it having another connector on it.
post #3 of 7 (permalink) Old Nov 19th, 07, 02:23 PM Thread Starter
wayne
Re: Extra wire
No I have the license plate light wire . This orange wire was plugged into the harness connector that the license plate light and fuel sending unit plug into. It was plugged into the fuel sending unit side of the connector and was about 3 feet long with a connector at each end and another connector at the bottom where it looks like you would plug the the fuel sending unit if you used the orange wire to run some sort of option.
together is offline
post #4 of 7 (permalink) Old Nov 19th, 07, 02:40 PM
click's Avatar
Re: Extra wire
maybe this helps.. not sure about plain orange tho.
click is offline
post #5 of 7 (permalink) Old Nov 19th, 07, 02:52 PM
Banned
Ron
Badbird's Avatar
Re: Extra wire
The fuel sending unit only works with the ignition key in the on position......If this orange wire is linked to it, then it works off the ignition (switched)......An optional trunk light would provide power all the time so this wire has to be for an optional rear defogger.
Badbird is offline
post #6 of 7 (permalink) Old Nov 20th, 07, 12:39 AM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Re: Extra wire
Sounds like a trunk light. There's a little Y-harness that the trunk light plugs into:
http://www.drclassic.com/catalog/Cam...g/WR28210.html
Could be, but it should NOT be piggybacked onto the fuel gauge sender.
Almost sounds like he is describing the extension harness for a glove box light, wonder what it's doing in the trunk?
How bout a pic of this things?
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #7 of 7 (permalink) Old Nov 20th, 07, 08:54 PM
clayton hicker
Re: Extra wire
i had onley the orange wire.my fuel gauge didnt work so i plugged in the orange wire and the gauge started working till i turned lights on the the gauge stops working
bikedude3 is offline
