Getting no spark with HEI - Team Camaro Tech
post #1 of 13 (permalink) Old Nov 20th, 07, 09:40 PM Thread Starter
I went to fire up the hot rod today and no go. I'm getting good fuel pressure and the plugs are clean. I checked for spark at the plugs and got nothing. I am getting some voltage drop at the coil wire (10.5V), however, my Holley Blue and 3 electric fans were running when I checked. I swapped the Accel HEI Super Coil (in-cap style) for a new one and still have no spark. Should I swap the ignition module? Do you guys have other thoughts on what to check?
Thanks. --Neil
Neil B is offline
post #2 of 13 (permalink) Old Nov 21st, 07, 04:42 AM
Re: Getting no spark with HEI
HEI needs a full 12 volts. Jumper in another battery?
All connections at HEI good? Those from the inside as well?
Good ground path from dist body to battery?
Rotor turning when cranking?
Spring & button still on coil? Making good contact?
Rotor have any carbon tracks?
I'd check the resistance of the pick-up coil, 1500 ohms or so.
If all above works, then replace the module.
Everett#2390 is online now
post #3 of 13 (permalink) Old Nov 21st, 07, 07:21 AM Thread Starter
Thanks Everett. How do I check the pick-up coil resistance?
Neil B is offline
post #4 of 13 (permalink) Old Nov 21st, 07, 08:31 AM
Make sure you have good grounds and that the wires are secure for the coil.
68 Camaro~LSx ~all motor
post #5 of 13 (permalink) Old Nov 21st, 07, 09:22 AM
You're welcome. Remove the cap, unplug the module from the coil and use the DMM in OHMs function and measure across the coil terminals.
post #6 of 13 (permalink) Old Nov 21st, 07, 09:39 AM Thread Starter
When you say measure across the coil terminals, do you mean across the terminals on the module pigtail that plugs into the coil?
Thanks again! --Neil
Neil B is offline
post #7 of 13 (permalink) Old Nov 21st, 07, 05:58 PM
Measure the coil leads, those leads disconnected from the module.
post #8 of 13 (permalink) Old Nov 21st, 07, 06:39 PM
How did you test that? With just the key on, its a little low, but with the engine cranking, about normal.
Greg U
undee72Z is offline
post #9 of 13 (permalink) Old Nov 26th, 07, 02:18 PM Thread Starter
Hey guys,
I checked the pick-up coil resistance and got 840 ohms. I then swapped the module for a new one and it fired right up. I put a new cap and rotor on for good measure.
Thanks for your help!
--Neil
Neil B is offline
post #10 of 13 (permalink) Old Nov 26th, 07, 02:20 PM Thread Starter
I checked with the key on (fuel pump and electric fans running). Voltage at the battery was 12.4.
Neil B is offline
post #11 of 13 (permalink) Old Nov 26th, 07, 04:53 PM
Neil in your original post you said you measured 10.5 volts at the coil. If the battery is at 12.4, that's nearly 2 volts drop. If you are in fact running HEI, be certain you have given it a full 12 volt feed via a copper wire instead of the cloth covered resistance wire GM installed for breaker point ignition. That may have lead to a module failure and certainly will affect spark performance.
dnult is offline
post #12 of 13 (permalink) Old Nov 26th, 07, 05:20 PM Thread Starter
Dave, it's definitely wired for 12 volts. I will continue to chase down the cause for the voltage drop.
Neil B is offline
post #13 of 13 (permalink) Old Nov 27th, 07, 09:53 PM
john
wagonman's Avatar
also, HEI coils req a 12-10 AWG primary wire for full coil saturation.....
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
