Help with Tail/Brake light problem - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 23rd, 07, 04:49 AM Thread Starter
Tonite, I took my 68 out for a quick spin to the liquor store and when I came out I noticed I had left the lights on, but one of my tailights was out. When I got home, I pulled the connector out of the housing and jiggled the globe a little and the tailight came back on. I then got my son to test the brake light, but when he applied the brake, the light went out. Same thing, jiggle the globe, on comes the light, apply the brake, light goes out. Any ideas? Is it a faulty connector? Globe looks OK.
AussieCamaroOwner is offline
post #2 of 6 (permalink) Old Nov 23rd, 07, 08:38 AM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Re: Help with Tail/Brake light problem
Common problem... the contacts corrode and make an intermittant connection to the bulb and/or the housing (ground). Aftermarket sockets are even worse than old original ones. I've seen other people have good luck with new factory-style sockets from AAW. For mine, I put LED conversions boards in.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #3 of 6 (permalink) Old Nov 23rd, 07, 05:52 PM Thread Starter
Update. Just to be sure, I purchased 2 new globes. Now the brake lights work, but the tail lights don't! When the lights are switched on, the brake lights don't work either, they only work when the lights are switched off. Help!
post #4 of 6 (permalink) Old Nov 24th, 07, 11:13 AM
Inspect the sockets for signs of heat fatigue and improperly aligned connections. Brighten up any burned areas, reshape any misalignment and then lightly dope the electrical connections with dielectric grease.
The problem with bad connections is that they snow-ball very quickly once they start. Dielelectric grease is one way of keeping things under control. It prevents oxygen from getting into the connection and leading to corrosion.
dnult is offline
post #5 of 6 (permalink) Old Nov 24th, 07, 02:01 PM
Fred
Memories! I hated those early GM bulb sockets. They fixed them in 69. All of my bulbs work great. All but two are original too.
Not sure of your 68 but the drill used to be; Clean, clean, clean.
128.79mph 1.428 60'
Fred Ficarra is offline
post #6 of 6 (permalink) Old Nov 26th, 07, 08:39 AM Thread Starter
Thanks guys. I got them working after some trial and error. I really want to upgrade to some LED tailights. Who makes the LED conversion kits that are not sequential?
