No brake lights,no tail lights,have blinkers - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 23rd, 07, 06:12 PM Thread Starter
Pat
I'm not a wiring guy...my car has been completely re-wired and all worked perfect before I sent it to the body shop for painting.Got blinkers no tail or brake lights...whats the deal.I called a guy I know and he says it sounds like I"ve lost the ground.Does that sound right? Where is the ground for this circuit how do I test this,track it down and fix it.The guy who wired the car is out of town for a while so need some help.I'm not a complete idiot when it comes to wiring...its just not my thing i'm totally comfortable with so...!
67pat is offline
post #2 of 4 (permalink) Old Nov 24th, 07, 08:41 AM Thread Starter
Pat
Re: No brake lights,no tail lights,have blinkers
bump
67pat is offline
post #3 of 4 (permalink) Old Nov 24th, 07, 02:08 PM
Fred
Pat, what's your car? First gen Camaro? Then pop the trunk, look against the drivers quarter panel for a wiring harness. It may have fallen into the well behind the tire. Pull it up and check for a separated plug. Good luck. But you probably won't need it.
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 4 (permalink) Old Nov 24th, 07, 02:10 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
ground is through the tail-light housings
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
