67' RS Rear Wiring - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 24th, 07, 09:51 AM Thread Starter
frank
Frankrentef's Avatar
67' RS Rear Wiring
Greetings all,
Have a 67' RS and a new rear wiring harness for my Turkey weekend project. One the end of the harness that goes to the fuse box... the new wiring harness has a plug. On the fuse box I don't see a plug (unless it's on the back) All the wires are screwed into the fuse box terminal.
Am I missing something (besides experience)?
67 Camaro RS - 383 Stroker
Factory A/C - Muncie 4 speed
Frankrentef is offline
post #2 of 10 (permalink) Old Nov 24th, 07, 10:07 AM
Re: 67' RS Rear Wiring
The connector for the rear harness is at (or behind) the top of the drivers side kick panel.
post #3 of 10 (permalink) Old Nov 24th, 07, 10:30 AM Thread Starter
frank
Ohhhhh...
THNX, now I'm missing a little less experience!
Any secrets to getting the kick panel off?
post #4 of 10 (permalink) Old Nov 24th, 07, 01:21 PM
Search "remove kick panel" and a ton of posts with good info will come up. Lots of fun...
Eric
Eric Kammerer is offline
post #5 of 10 (permalink) Old Nov 24th, 07, 02:55 PM
You won't need to take the whole thing off (thank the Lord!)
If you pop the rear off the door pinchweld, you should be able to pull it out far enough to fish the harness.
You'll be able to get to the connector over the top, it will pull right up.
post #6 of 10 (permalink) Old Nov 25th, 07, 06:42 AM Thread Starter
frank
THNX,
Can you clarify "door pinchweld"? I'm learning as I go... and loving every minute!
post #7 of 10 (permalink) Old Nov 25th, 07, 08:20 AM
Where the back of the kick panel wraps around the door opening.
A "pinchweld" is anyplace where 2 peices of metal are butted up and spot welded together. Probably the most "famous" pinchweld is where the floor meets the rocker, under the car. There is also a pinchweld all around the door opening, and many other places.
post #8 of 10 (permalink) Old Nov 25th, 07, 08:48 AM Thread Starter
frank
Thnx,
I'm assuming that since this "pinch welded" that the weld or similar seal will need to be replaced? If so, what type of seal / sealer?
In other postings I've read of differences between a/c and non a/c kick panels. Besides the vent in non a/c cars is there any difference to breaking the weld / pulling the kick panel off?
Mine is an a/c car.
post #9 of 10 (permalink) Old Nov 25th, 07, 09:32 AM
naaa, nothing will need to be replaced. The kick panel just wraps around to cover the edges and make it look good. You can pop it off carefully, and pop it back on when you are done. I use a 1" putty knife that I heated up and bent into a U shape, and wrapped in duct tape to keep from scratching any paint. When I was younger (lol!) I could pop em on and off with my fingers.
Other than the vent, there won't be a difference with the kick panels.
post #10 of 10 (permalink) Old Nov 25th, 07, 12:19 PM Thread Starter
frank
THNX,
I'm anxious to get my back lights working so I can drive it somewhere besides around the neighborhood / nearby back roads.
