New American Autowire harness install - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 24th, 07, 05:54 PM Thread Starter
I am installing an American Autowire harness in a 68 Camaro Convertable. Can anyone help me with the pink and yellow wires that go to the coil and starter? Thanks so much, Rick.
rlarew1 is offline
post #2 of 8 (permalink) Old Nov 24th, 07, 08:14 PM
Steve A.
flat350's Avatar
Send a message via AIM to flat350
Re: New American Autowire harness install
Sheet J the engine kit has pretty clear instructions as to where they go ,do you have the ballast resistor ? If you need further help try talking to Donny in tech at AAW , he was a tremendous help to me when I did my 68 . I'm running a HEI dist. so mine is wired differently than if you use a points dist.
68 work in progress , but I can drive it now - O5D build - 712 trim - 02 color
Think it was a 396 , 4 spd. - now in primer , 350 , 4 spd. , lots of new body and mech. parts
flat350 is offline
post #3 of 8 (permalink) Old Nov 24th, 07, 08:57 PM
Rick, which AAW harness are you installing, Factory Fit or Classic Update? I'm guessing Update, because otherwise there would be a yellow and a white cloth covered wire.
The pink is your 12V ignition feed wire. If you're running a non-points setup (HEI or similar distributor), the pink wire goes directly to the positive (+) side of the coil. If you're running points, the pink wire goes into a ballast resistor first, then to the + side of coil. A points car needs the voltage reduced to less than 12V constant, to keep from frying the points, hence the ballast resistor; an OE harness (and the Factory Fit harness) uses a cloth covered resstance wire to do the same thing.
The yellow is the 12V full voltage during strartup for a points car; the points do get a full 12V when the starter is engaged on an OE setup. The yellow wire would go from the "R" terminal (small terminal lug closest to passenger side of car) to the + side of the coil, or to the "downstream" end of a ballast resistor on a non-OE style installation. If you are running HEI or the like, you do not need the yellow wire at all.
I'm guessing that's what's throwing you off, looking at the little box on the Engine Kit 500668 instructions. If you have HEI, just hook the pink to the + side of the coil and throw the yellow back in the box.
Welcome to Team Camaro!
Eric
Eric Kammerer is offline
post #4 of 8 (permalink) Old Nov 25th, 07, 11:23 AM Thread Starter
Wow you guys are great! I am a new member and really appreciate all your help. I am installing the Classic Update. I am using the original distributer with electronic points. For some reason I just cant get my arms around something that should be simple. Thanks again for all of your help, Rick.
rlarew1 is offline
post #5 of 8 (permalink) Old Nov 25th, 07, 11:24 AM Thread Starter
I forgot to mention that there is no ballast resistor. Thanks again, Rick.
rlarew1 is offline
post #6 of 8 (permalink) Old Nov 25th, 07, 11:31 AM
[quote=rlarew1;892534]Wow you guys are great! I am a new member and really appreciate all your help
Welcome to Team Camaro!!
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #7 of 8 (permalink) Old Nov 25th, 07, 12:31 PM
Banned
Ron
Badbird's Avatar
We know we are!!.....That's what we're here for!!.....To help and offer assistance to get you on the road as quick as possible so you can enjoy your new Camaro!.....Welcome to the club, man!
Badbird is offline
post #8 of 8 (permalink) Old Nov 25th, 07, 02:56 PM
Ok, so you're set! Pink to + side of coil, leave the yellow in the box.
Eric
