New set of guages = no electric? - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 28th, 07, 06:47 PM Thread Starter
Matt
I just replaced 3 gauges (Oil Pressure, Temp, and Battery). They were aftermarket style gauges. I put in SunPro gauges.
The wires for the battery gauge and the oil line for the oil pressure gauge were all there, so it was just a matter of swapping them to the new gauge.
Now the trouble:
I hooked the battery back up (just had the negative off), and the battery gauge shows how many volts I have, right at 12. But thats the only thing that seems to have any type of power to it. I don't have any lights, no radio, and turning the key doesn't do anything. I unhooked the wires off the battery gauge and still didn't get anything.
The only thing that involved anything electrical was the battery gauge, and that was just a transfer to the knew gauge. I checked my fuses, and they all look pretty good - but even if one did go, I should still have lights, radio, or some form of engine noise?
What could be causing this? Thanks for any advice!
Fewski is offline
post #2 of 9 (permalink) Old Nov 28th, 07, 06:52 PM
Re: New set of guages = no electric?
what you called a 'battery gauge', is it a voltmeter or ammeter? if it was a an ammeter, it might be the circuit connector for the whole system. eliminate it from the circuit and see what happens.
guccieng is offline
post #3 of 9 (permalink) Old Nov 28th, 07, 06:56 PM Thread Starter
Matt
Thanks for the reply. It is a voltmeter.
Fewski is offline
post #4 of 9 (permalink) Old Nov 28th, 07, 07:12 PM
Greg
Take your ground back off and check for corrosion,if that is all you did then it has to be a defective ground, unless the fusible link blew from the batt pos term to the radiator support junction block.
1969 RS/SS Vert
1031 Engineering llc
chops is offline
post #5 of 9 (permalink) Old Nov 29th, 07, 10:38 AM Thread Starter
Matt
Ground looks good. If the ground was bad, it wouldn't show how many volts, would it? Thanks for the reply.
This is strange.
Fewski is offline
post #6 of 9 (permalink) Old Nov 29th, 07, 10:54 AM
Was the old gauge that you replaced also a voltmeter?
It kinda sounds like you put a voltmeter in where an ammeter used to be.
post #7 of 9 (permalink) Old Nov 29th, 07, 11:59 AM Thread Starter
Matt
That sounds about right... I got off the phone with SunPro and they were a great help with ideas and how it all works. Turns out what you said is what they also said, needless to say, I hooked up the Amp gauge and am about to take it for a ride to check out the temp gauge.
Thanks all.
Fewski is offline
post #8 of 9 (permalink) Old Nov 29th, 07, 01:45 PM
This is strange.
Not at all. A volt meter is a very high impeadance device meaning it doesn't take much amperage at all to make it register (micro amps in fact). A bad connection will have no problem making a volt meter register.
But, when you try to pull substantial current through a bad connection all voltage disapears because the resistance in the connection can't sustain the current demands.
Be careful with your meter. Volt meters and Amp meters are vastly different and if you do things incorrectly you could end up with a fire.
dnult is offline
post #9 of 9 (permalink) Old Nov 29th, 07, 01:59 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Actually, the factory amp meter in our first gen Camaros is a low-voltage volt meter--it measures the voltage drop across the alternator battery wire between the alternator and the battery to approximate amperage. If he previously had an aftermarket ammeter that didn't use a shunt, then yeah you are correct.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
