Source for rubberized wire clamps - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 7th, 07, 10:53 AM Thread Starter
Kevin
I'm trying to figure out a good way to route wires down to my starter without burning them up on my headers. I have some wire braid that I can put the wires into and found a good way to route them down the back of my block and down the back side of the passenger cylinder head. There are a number of bolt holes in my head that I can secure a clamp to but can't find a source for a clamp.
I purchased some rubberized clamps from American Autowire (part 500082) and they would be great except the hole to secure them to something is too small and I need about a 5/16" or 3/8" hole for my bolt. The pad on the clamp is too small to enlarge it this much.
I can't clamp things to my firewall like I did in the old days because its been painted and smoothed...
Has anyone found a 1/2" size rubberized or other non-sharp way to secure cables with a larger hole for mounting it to something that takes a larger 3/8" bolt ?
'68 RS Camaro, 454 SBC
'69 Camaro, body only
MissionCritical is offline
post #2 of 7 (permalink) Old Dec 7th, 07, 12:30 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
Re: Source for rubberized wire clamps
you could make a small L-bracket that bolts to the head, and then bolt a reasonable-sized clamp to the bracket.
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #3 of 7 (permalink) Old Dec 7th, 07, 12:47 PM Thread Starter
Kevin
Yeah, I thought of that and might have to go that route. I just wanted for once to be able to buy something and bolt it on without having to fabricate something.
It seems wierd to me that there are a lot of fancy and nice looking wiring replacement systems out there, but when it comes time to strap, bundle, or otherwise attach it in a manner that looks clean, its hard to find something. I even had a hard time finding a nice looking wire cover and finally found something at Painless, although its a bit expensive.
post #4 of 7 (permalink) Old Dec 7th, 07, 01:26 PM
The clamps like the factory used are readily available at the repro houses. They got big bolt holes. Factory routing used the heater box and bellhousing bolts.
post #5 of 7 (permalink) Old Dec 7th, 07, 02:32 PM
Todd
All you need to do is get a round file and you can use a 5/16th bolt easily on those clamps. Just did it last week.
Vegas69 is offline
post #6 of 7 (permalink) Old Dec 7th, 07, 03:43 PM Thread Starter
Kevin
I'll feel dumb if after all of the searching my Classic or Ricks catalogs that stay on the top of the desk have what I need in it. All I can find in them though for clamps are the battery cable clap that bolts on the oil pan (KW567 in Classic catalog), or the heater box wire retaining clips (HC-28 / HC-29 in Ricks). But these are open clips and what I'd prefer is a closed loop.
If you know of a usage or section where the 'loop' clamps were used or of a part number, let me know.
I promise to post pictures soon of my project. If there was an award for spending the most money and having the least to show for it, I'd win !
post #7 of 7 (permalink) Old Dec 7th, 07, 03:46 PM
The factory style clips are open.
I understand what you're looking for now.
Have you been through the "drawers and drawers" full of stuff at your local Ace Hadware?
Bet they gottem.
