Need help locating a part for 69 horn contacts - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 7th, 07, 06:07 PM Thread Starter
I need to find the small brass terminal connector that connects the horn contact wires together so they can be installed on a friend's 69 Camaro. None of the repro outlets that I have contacted stocks that little part. Any information as to where I can obtain this part is greatly appreciated.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #2 of 11 (permalink) Old Dec 7th, 07, 09:10 PM
prostreet69camaro's Avatar
Re: Need help locating a part for 69 horn contacts
Are you talking about the wire that has the spring and clip. It is the one that connects to the round horn contact and goes through the steering wheel. If it is then I have the GM part number. It is 09769448 and and is called lead asm. If you need a picture of it let me know.
prostreet69camaro is offline
post #3 of 11 (permalink) Old Dec 8th, 07, 05:03 PM Thread Starter
Yes,
Please post a pic.
Turbo 400
post #4 of 11 (permalink) Old Dec 8th, 07, 11:21 PM
Steps
A spring out of a ball piont pen, stamp a small brass contct and solder, and O think from memory there is a outter insuation tube??? if so Im sure I used the ink tube out of the pen...cleaned
So long ago I did it...and still works after all these yrs.
Steptoe is offline
post #5 of 11 (permalink) Old Dec 9th, 07, 07:47 AM Thread Starter
That's very interesting information! Thanks.
Turbo 400
post #6 of 11 (permalink) Old Dec 9th, 07, 10:55 AM
Here is the picture.
post #7 of 11 (permalink) Old Dec 9th, 07, 05:08 PM Thread Starter
Thanks for the pics!!!!
Turbo 400
post #8 of 11 (permalink) Old Jan 22nd, 08, 08:53 AM
J
Question: how does this part connect to the cam assembly (cam and spring). This is the cam and spring that sits in the horn tower?
jkkrs310 is offline
post #9 of 11 (permalink) Old Jan 23rd, 08, 06:40 PM Thread Starter
Check out this thread. There are pics that describe what you are asking about. In one pic a pin and spring are discussed. The pin,depending on the type of steering wheel used,may or might not be used. I have a 69 with a standard wheel and tried to use the pin but ended up not using it and just used the spring.
https://www.camaros.net/forums/showth...300#post891300
Turbo 400
post #10 of 11 (permalink) Old Jan 24th, 08, 08:49 AM
J
This is very helpful. The plastic horn tower on my car is broken and sits behind the steering lock plate??? This is the plate with cogs on the end. There's another plate on top of that with 3 phillips screws that can be easily removed.
To buy a new horn tower....is it part of the canceling cam? I thought I saw a similar piece at Classic Industries that's included in there wood steering wheel adapter kit.
Thanks!
jkkrs310 is offline
post #11 of 11 (permalink) Old Jan 24th, 08, 06:09 PM Thread Starter
Yes, I believe it is part of the cancelling cam.
Turbo 400
