Restored voltage regulator - Team Camaro Tech
post #1 of 20 (permalink) Old Dec 9th, 07, 09:54 AM Thread Starter
"Tri-Tip"
Gary L's Avatar
Are there any problems with using an original regulator? I am using a Delco replacement mechanical type now.
Gary L is offline
post #2 of 20 (permalink) Old Dec 9th, 07, 12:06 PM
Steps
Re: Restored voltage regulator
Unless u are lookung at a full matching numbers car...convert to a self regulating alternator...saves a lot of messing arond and the conversion is simple once u work out which wires go where...
there are many old posts that have instructions and diagrams.
Steptoe is offline
post #3 of 20 (permalink) Old Dec 9th, 07, 12:16 PM
Wells VR715 is a remote regulator as your system now has, but it is electronic, not point. This regulator makes the early remote regulator alternators function same as the later internal regulator alternators do.
The Delco-Remy cover can be interchanged for a stock appearance.
Regards,
Milton
The Devil's advocate is offline
post #4 of 20 (permalink) Old Dec 9th, 07, 01:09 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Thanks, but no thanks. Not changing my 837 alternator to something else. I am into originality.
Regards,
Milton
Thanks, but I still am looking for the answer to the question I asked.
Gary L is offline
post #5 of 20 (permalink) Old Dec 9th, 07, 01:14 PM
Kevin
KevinW's Avatar
Gary, I run original regulators. If it works, it works, if not, then it doesn't. doesn't hurt anything when they fail. They can be rebuilt too. Do you have one or do you need one? what dates?
Kevin
KevinW is offline
post #6 of 20 (permalink) Old Dec 9th, 07, 01:18 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Thanks Kevin. I have a restored 9B for my 02D car from a good source, I hope.
Gary L is offline
post #7 of 20 (permalink) Old Dec 9th, 07, 03:01 PM
You need to check and adjust them periodically, but they will get the job done. I'm sure it's no surprise that the electronic replacement will last longer, regulate better and not require any adjustments.
dnult is offline
post #8 of 20 (permalink) Old Dec 10th, 07, 10:06 PM
When you set the regulator, run the engine for a while with the cover on it, to make sure the temperature inside the regulator doesn't change the settings. If so, pull the cap and reset, put cap back on, test, etc.
Keep ground paths, and all wires clean and tight.
Hope this helps to answer your initial question.
Regards,
Milton
post #9 of 20 (permalink) Old Dec 10th, 07, 10:17 PM
Lane
Mine has been in service since 1976. Wish I hadn't thrown the original away. Lost a couple ebay auctions at about $380 for a numbers match.
Have never set it, but did run some fine sandpaper across the points to bring them back to life couple weeks ago. Never had a problem other than that.
67 RSS is offline
post #10 of 20 (permalink) Old Dec 11th, 07, 08:18 AM Thread Starter
"Tri-Tip"
Gary L's Avatar
Regards,
Milton
OK, my turn for a dumb question. How do you adjust/set them?
Gary L is offline
post #11 of 20 (permalink) Old Dec 11th, 07, 11:26 AM
It's not an easy adjustment, but time consuming.
Make sure alt belt is in good condition and adjusted correctly.
Start and run the engine at high idle through and to operating temperature.
Remove battery caps, yeah, right, and measure the charge of the electrolyte and note its temperature.
Measure temperature of regulator at the cover.
Find in an older Motors Manual, and use the look-up chart for temperature to voltage output.
If low or high, cover needs to come off, either remove rivets, or remove cover screws. Straight off is the direction, otherwise, the cover shorts out the relay contacts.
On the voltage coil, the upper one, you will see a spring. Using needle nose pliers or the special tool, lengthening the spring (increasing tension) increase voltage; shortening the spring, decreases the voltage.
After each minute adjustment of the spring, cover must go back on to keep reg warm.
If making current adjustment, turen off engine and remove battery cable and insert a VAT-28 or use the pick-up clamp from the VAT-40 and load the charging system with the carbon pile resistor, inside the VAT and adjust the contact gap for max output as stamped on alt housing.
Recheck voltage again and adjust as needed.
Even after doing the above, every week check the electrolyte level of each cell. If level is low, monitor elec temp. If hot, voltage set too high, lower voltage setting. If battery needs a charge, set voltage level higher.
You can measure across the battery posts and with lights, heater, engine running, make sure it does not go below 13.2 volts. All accessories off, no more then 14.5 volts.
Or replace it with A Wells VR715 and forget it.
post #12 of 20 (permalink) Old Dec 11th, 07, 01:11 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Uh, I only needed to know which screw to turn.
Gary L is offline
post #13 of 20 (permalink) Old Dec 11th, 07, 03:38 PM
Depends on build date(?), some have a screw, some don't.
Principle is still the same, lengthen the spring to increase voltage and vica versa.
post #14 of 20 (permalink) Old Dec 12th, 07, 01:52 PM
That is why the electronic regulators are so far advanced over the point ones. Motor's Manual's has a complete set of instructions to follow, libraries have them to look at.
Regards,
Milton
post #15 of 20 (permalink) Old Dec 12th, 07, 07:53 PM
joseph l clance
joe clance's Avatar
Put your original regulator cover/cap over an electronic version regulator base and avoid the hassel!
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
